Well, not being an old timer nor an electrician, I've not seen this before. I consulted with my local "sparky" and his opinion was to have the local utility relocate to the exterior. My report stated that the utility is responsible for the transformer and the utility rep said the owner/seller is responsible for the can. I recommended that box be moved outside utility said they probably would not unless paid to do so. I asked them about their liability, considering that it is at floor level and easily accessible to kids, etc. The response was a sticker stating that the components were the property of the Public Utility District, NO locks on box. I feel like this is ultimately between the seller and the utility, however, my basic concern is safety. Any advise or opinions would be highly appreciated.
Randie L. Carley Simcoe Inspection Services, LLC (509)-250-2617 Cell (509)-773-4864 Office "It's not our differences that divide us, it's our inablility to recognize, accept and ultimately, celebrate those differences." http://www.simcoeinspections.com/ |
I see no problems, save for the fact that a CT can is supposed to have a seal tag, lead seal, or a padlock provided by the utility.
The only problem I have with it is how EASY it was to get into it....I would consider it a liability if I had small kids in the house....they need to figure out a way to seal it up...
But alas......it is POCO's and well.....we could not do alot about it anyway so all is good.....just note that it should be sealed to prevent children and young adults wanting to end life quickly from getting into it. Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
I would call this a 230.70(A)(1) violation but I run on the stricter side of this ambiguous language.
This is a judgement call so other inspectors will have other opinions. |
I have never seen CT Cabinets inside a home before and believe they should be at the exterior near the meter and usually are sealed by the Public Utilities for that area.
I have found this to reiforce that statement, which is in Colorado Springs, http://www.csu.org/extrx/util_dev_sv..._chapter_5.pdf And yet another that agrees in the same way. http://www.chugachelectric.com/pdfs/...section300.pdf It might be prudent to check with the requirements of the local jurisdiction of that particular area you are in at the time. I can not imagine they would allow this in most places. But that is just my opinion. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Thank you, again you've shown your professional attitude in offering help to those of us with less experience. You guys rock.
There is no general prohibition against indoor CT cans, save for POCO rules. For every POCO that required them outdoors, there's one that will permit them indoors. Matter of fact, most larger indoor switchgear has the CT can (called CT section) built into the switchgear at the factory. There is no hazard in the photo, other than the lack of sealing. |
Pop quiz...
Homes that have a 200 amp CT can indoors, where they could have had traditional across the line metering equipment, normally also have the phone NID (demarc), and CATV splitters mounted indoors also. Why do you suppose that is? I know the answer, but I'm just encouraging a little expanded thinking... |
And you are right, they do allow them indoors as you said, like this photo; Attachment 15342 But this is not the standard for Residential and far from it. They even have monitoring systems integegral also like this. Attachment 15343 All I am saying is that different Utilities will prohibit interior CT cabinet installations, so it would be wise to check with that first before one inserts foot in month. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 Last edited by mcyr; 4/9/08 at 8:43 PM.. |
Agree ,it was approved by someone on the original timeline.
But this is being inspected for a client and the client needs to be made aware of this installation, for any extensive repair that might occurr in the future, there might be a possibility of an upgrade to the electrical system an this portion there/of might have to be re-installed to more current standards and compliance to the local Authorities. JMO Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
cgoyette is a non-member guest and is in no way affiliated with InterNACHI or its members.
Could someone explain without acronyms what this CT (spelled out) is. In the south I have not seen one at least not what the picture shows in the first post. What does it do what are the concerns?
Curt |
You'll find indoor CT cans for 200 amp services in some homes where security was a prime concern. These are typically homes originally constructed for people like congressmen, company CEO's, CIA agents, and so fourth. The service conductors arrive from underground, directly from the padmount transformer. The service conductors run through the CT, and right to the panel's main. The metering conductors are just little wee conductors run to the meter outdoors. This prevents future ne'er do wells from pulling the meter to put the place in the dark, since the service conductors don't even appear at the meter. |
Wow...that hurts! InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
| Common Defects List by Age of House | trausch | Inspection Education & Training | 10 | 6/12/06 5:52 AM |
| No Ashi / Nachi Conflict!! | fcarrio | Legislation, Licensing & Legal Issues for Inspectors | 5 | 2/11/06 2:32 PM |
