Old 1/10/10, 7:40 AM
Greg Bell's Avatar
Greg Bell Greg Bell is offline
Default Cutler-Hammer Panel Defect
A friend just built his house a couple of years ago. He noticed that he wasn't getting much heat from his furnace. So he called another friend that did his HVAC work and asked that he come out and diagnose the problem. He found out that the air handler wasn't getting enough power for the heat strip. He traced it back to the panel. After opening the panel they could see that the breakers were melting. He removed a few breakers and the aluminum bus bar was covered in plastic. So the homeowner called the electrician (another friend). He came out and called the supply company, who put him in touch with a cutler-hammer representative. The representative acknowledged that they were aware of the problem and that they would send out a replacement panel.
So pay close attention to any cutler-hammer panels you come across that are less than 5 years old.
Greg Bell
Titusville, Fl
02111507
Serving Central Florida
Need a home inspection in Iowa? Check out InterNACHI's listing of Iowa certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/10/10, 7:57 AM
David P. Valley's Avatar
Default Re: Cutler-Hammer Panel Defect
Thanks for the info.
Wow, I'd love to get those pics.
Is it possible Greg?
Old 1/10/10, 8:08 AM
Greg Bell's Avatar
I don't have any pics yet. The electrician pulled all of the breakers out and cleaned the bus bar. I will see what I can get in the next couple of days.
Greg Bell
Titusville, Fl
02111507
Old 1/10/10, 8:14 AM
Good info. Thanks for the heads up.
Larry Kage, CMI
231 929 3525
Old 1/10/10, 8:21 AM
Jim Port Jim Port is offline
Unmoderated Guest
CH series panels have copper buss. The cheaper BR series uses AL buss.
Were the proper breakers used in the panel?
I have seen the same condition in other brands also.
Is there an official recall notice or formal notification that you can link to?
Old 1/10/10, 9:43 AM
The CH Series has Silver Coated Copper Buss and has a lifetime warranty. I would only install CH Series...but again I am a bit partial.
Paul W. Abernathy
Old 1/10/10, 9:46 AM
Greg Bell's Avatar
Jim
I don't know of any recall or bulletin that I could link too.
Paul,
Greg Bell
Titusville, Fl
02111507
Old 1/10/10, 11:30 AM
Bruce A. King's Avatar
Hope to find out which series panel it was....
The BR series is gray and uses 1 inch breakers, has 10 yr warranty.
The CH series is tan and uses 3/4 inch breakers, has lifetime warranty.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 9/4/10, 9:01 AM
Greg Bell's Avatar
They changed the panel. Here are some pics.
cutler-hammer-panel-defect-dscf0001.jpg   cutler-hammer-panel-defect-dscf0002.jpg   cutler-hammer-panel-defect-dscf0003.jpg
Greg Bell
Titusville, Fl
02111507
Old 9/4/10, 9:25 AM
Robert Meier's Avatar
Is this a common defect in the breaker? Any idea what caused this?
Old 9/4/10, 12:27 PM
Mark Thorman Mark Thorman is offline
Unmoderated Guest
Please Note: Mark Thorman is a non-member guest and is in no way affiliated with InterNACHI or its members.
http://www.consumeraffairs.com/homeo...er_hammer.html
www.MauiHomeInspections.com
Old 9/4/10, 12:52 PM
Originally Posted by Mark Thorman View Post
I didn't see any information in that link regarding the branch circuit breakers snapped onto the bus. Only a mention of some loose bus bolts. Or did I miss something?
Old 9/4/10, 1:05 PM
Unmoderated Guest
"The reason the breaker tripped was because it was overheating/melting."
Old 9/4/10, 4:23 PM
Maybe it's me, but I'm not seeing how a loose bolt on one end of the bus will melt the CB at the other end as depicted in the photo.
Old 9/4/10, 5:34 PM
Unmoderated Guest
I agree. But worth digging deeper.
Electric Panel dmozzillo Electrical Inspections 26 1/26/09 1:18 PM
Cutler Hammer panel with Square D breakers bhartley Electrical Inspections 3 11/25/08 9:48 PM
Sq D 200 amp panel with Cutler Hammer Breaker lfoster Electrical Inspections 7 6/28/07 10:06 PM
