Does anyone know the date for the requirement that all electical service is shut off to a house with no more than " 6 throws" of breakers? 1971 GE service - (see the Approved sticker). I know, aluminum wire, multiple grounding and grounded conductors together under a single screw -
I expect an argument from the AHJ, seller, broker - since there is an Approved sticker it must be okay - |
| Find an InterNACHI certified California Home Inspector (and anywhere else in North America) |
I think the second two pole breaker down on the right side feeds the lower half bus. What size is that breaker? Need a higher res pic. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Thanks Mike - you may be right. I followed all the wires but could not see the termination of that breaker. But just for my knowledge, do you know of a date for the requirement?
Not sure but that has been around for decades.
Frank - you are right - and there have been many changes since the "Approve" install - mostly to remove the alum wire - but to most people, once approved, always approved -
Thanks Mark - always wanted to know how far back it goes - |
| Need help with Date of MFG | pcarter-old-04 | Inspecting HVAC Systems | 7 | 3/16/11 10:45 PM |
| Democrats Enacting Gun Control - I Told You So..! | jmckenna1 | Miscellaneous Discussion for Inspectors | 42 | 2/17/09 1:38 PM |
| ASTM meeting date and venue confirmed. Everyone welcome. | gromicko | Miscellaneous Discussion for Inspectors | 8 | 8/20/07 3:06 PM |
