Old 12/29/10, 8:04 PM
Default DC rated switch question
Anyone know of any typical style toggle switches rated for 115VDC?
Jeff
Jeff Wicklander
Corwick Home Services
Join my business on Facebook
Need a home inspection in Ohio? Check out InterNACHI's listing of Ohio certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/29/10, 8:12 PM
Jeffrey R. Jonas's Avatar
Default Re: DC rated switch question
Did you try Eaton or Honeywell websites? Do you know the amp rating?
Old 12/29/10, 8:15 PM
20 amp breakers. I haven't looked there yet. Looked at Leviton and Hubbel.
Jeff
Jeff Wicklander
Old 12/29/10, 10:36 PM
Stephen W. Stanczyk's Avatar
Jeff, what is the application?
Stephen Stanczyk
Old 12/29/10, 11:30 PM
The lighting is coming off a GE Lighting Control Panel. Panel contains xformers and a rectifier. Input is 208VAC 3Ph and output is 115VDC. Switches are located in an MRI suite. Original electrical contractor put in standard commercial 20 amp 120/277V rated toggle switches. Problem is that DC arcs longer than AC and damage, due to heat, occurs pretty quickly. One switch stopped working all together while the other is still arcing with a nice greenish light(copper/brass). I would hate to tell the guy he needs a pair of contactors up above the ceiling when all he thought that was needed was a new $5.00 switch.
Jeff
Jeff Wicklander
New article on spill switch inspection inxil InterNACHI & RealMatcher Blogs 1 10/20/10 12:44 PM
Electrocution by 3-Way Switch Wiring? sbarrett Electrical Inspections 4 4/20/10 8:17 PM
Safety Switch for Restaurant hmcbride Electrical Inspections 9 3/19/07 12:04 PM
