This panel has a signifcant amount of lint like debris and dust on all components of the panel. Recommend cleaning or leave it alone?
www.MauiHomeInspections.com |
| Need a home inspection in Tennessee? Check out InterNACHI's listing of Tennessee certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
If error, error on the side of safety. I would feel completely comfortable calling it.
Greensboro Home Inspection Providing home inspections in Greensboro, High Point, Burlington and the surrounding areas. greensboro-home-inspection.html Raleigh Home Inspection Home inspections in Raleigh, Durham, Cary, Chapel Hill, Apex and surrounding areas. Raleigh-home-inspection.html BassRumors.com Providing a blog, news, and forum dedicated to bass fishing. |
I am surprised that when you pulled off the cover, the dust did not ignite and make a big flash. I have had that happened a few times, back when I was an industrial electrician. You will learn to turn your head away when you pull a cover off a live dusty panel. The flash can be so great it will blind you for over a minute. Also it will scare the crap out of you, the first time it happens.
There is a reason for this condition.
Did you find out the "why" comment on that? It is likely connected with a wide array of "significant issues" you should have in your report. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
Correct. The home is a high rise condo (7th floor) and the panel backs up to a chase wall. The panel is also located in the laundry closet so when the dryer is on and the door is closed air is filtered thru the panel. www.MauiHomeInspections.com |
While functional as-is (for now) I would definitely recommend cleaning and sealing of any panel openings to try and prevent future intrusion.
Very Good!
