bkelly1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
What is the most important defect here? Can you spot it?
All I can tell from that pic is that they are 30 amp fuses.
Looks like 3-wire NM inside the LFMC. Other than that, it's difficult to see much. . .
sparksnmore is a non-member guest and is in no way affiliated with InterNACHI or its members.
Box upside down ?
30 amp fuses on #12 wire
The disconnect is mounted correctly, the handle and blade attachment is broken and the handle is in the off position, all wiring is still "hot" due to the break in the handle..The "blades" are still in... Granted, it is a little hard to see in the picture.
The disconnect is broken.....no way to shut it off safely
dad burn it we posted at the same time. Do I still get a prize?
By the way, I see a lot of them like that. Sometimes, when the insulating part is completely gone, the metal bar will contact the energized line terminals when someone tries to put the handle up. I saw an apartment manager do this repeatedly, a shower of sparks each time.
Also, looks like thats a fused neutral.
It appeared to me that the black and white wires going to the bottom of the fuse-block may be the the hot and neutral of the same 120V circuit - though now that I looked again, that's probably feeding an AC.
| Defect recognition t S. Colorado NACHI Chapter meeting in Colorado Springs, April 12. | gromicko | Miscellaneous Discussion for Inspectors | 2 | 3/24/11 7:55 PM |
| Defect recognition CD available to NACHI members first, at a NACHI member price. | gromicko | Special Discounts for InterNACHI Inspectors | 4 | 8/1/06 12:12 PM |
| Photo Defect Recognition | dverge | Miscellaneous Discussion for Inspectors | 2 | 5/28/06 9:46 AM |
| Order this defect recognition CD first. | gromicko | Miscellaneous Discussion for Inspectors | 4 | 5/19/06 2:46 PM |
| Coming soon, defect recognition CD. | gromicko | Miscellaneous Discussion for Inspectors | 2 | 4/7/06 8:54 AM |
