Couldn't believe this...coax between the fixture and the light bulbs. Florescent or not, it's still incredibly stupid! This was one of the least dangerous electrical issues in this house. Some homeowners shouldn't mess around with any wire!
| Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
May cause the bulbs to break but not hot enough to melt the covering more than likely.The guess here is that the cable was originally run across the floor and he did not have enough wire to go above on the ceiling ,fasteners,or know how to cut and splice the cable.
Most Cable companies charge very little to run it for you. |
They got it above the drop ceiling and the light was only hung by chains! Here are some other fun ones from this house...
Some of the things I see, just shake my head wondering how could this not have burned down already. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
In another thread a comment was made about changing the SOP. Here is a good example of where, in my opinion the SOP needs to address calling in the local building official for their evaluation of the system. To simply state that it needs to be evaluated by an electrician will not get the proper repairs done unless the owner sees the danger. The electrician cannot force the repair.
This would force the repairs should they want to keep power to the premises. I know, this will not happen but it is still my opinion. Mike Whitt Contractor/Instructor |
Many of the homes in this area (Detroit metro) have gone vacant and are required to have a city inspection when they are occupied again. This house was one of those. Due to these and some other issues my client (wisely, IMO) walked away. Homeowner electricians scare me...
| Four Point Inspection Question (Electrical) | khunt | Florida Inspectors | 43 | 12/18/11 4:26 PM |
| Master Inspector - THE DEFINITION | mrowan | Miscellaneous Discussion for Inspectors | 128 | 12/11/06 1:50 AM |
