Old 9/11/07, 11:14 AM
rwilcox rwilcox is offline
Default Detached garage
Is this right? There's one shop light and one receptacle.
Old 9/11/07, 11:49 AM
wsiegel wsiegel is offline
Default Re: Detached garage
It may work, but you have three ground wires under one screw, which is not allowed, and the top feeds are double tapped, which is not allowed, and you have white wires improperly marked and being used as hot wires.
Old 9/11/07, 12:15 PM
Where are your neutrals?
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 9/11/07, 12:29 PM
Mike Whitt's Avatar
Unmoderated Guest
No
there are several things wrong
Old 9/11/07, 1:04 PM
Thumbs down Re: Detached garage
Thanks for the help, this is one of 4 DIY subpanel jobs and they all have issues, I will refer this mess to Sparky.
Old 9/11/07, 1:49 PM
tdietrich1's Avatar
Is this back-feed through the breaker supplying two 240(ish) circuits?
Just thinking out-loud, official answer it looks confusing.
tom
Old 9/11/07, 4:19 PM
Jeffrey R. Pope's Avatar
There is nothing proper about this installation. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 9/11/07, 4:28 PM
I don't think I've ever seen the likes of that before...
I wonder what the rest of the 'wiring' looks like?
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
Old 9/11/07, 10:28 PM
Wow. All I can say is WTF?
Old 9/12/07, 8:17 PM
Marc Benz Marc Benz is offline
Please Note: Marc Benz is a non-member guest and is in no way affiliated with InterNACHI or its members.
I did see that before and i have to expain that to the comuster about this situation and this type what you show to us on the photo that if that wired for only 120 volts the netrual is never be switch or controled by breaker or switch and this is very dangerous pratice. [ this is not allowed the netural to be fused/breaker after 1930's so it is in the code senice that time ]
And i think there are some issue it will crop up is the permits i know pretty good percentage of HO[ Homeowners ] don't bother to get the proper permits to do the job safe.
the other area is the spa tub but i think i will leave this in other area for now if want to talk about it we can run seperted thread on this one.
Merci , Marc
Old 9/13/07, 12:15 AM
Marc is right. The biggest problem here is that this is a 120 volt panel with an OCPD on the neutral. Bad news.
Installing GFCI in garage with no ground cyezza Electrical Inspections 53 11/30/07 5:05 PM
Evaporative cooler in garage chellickson Inspecting HVAC Systems 9 7/23/07 12:08 AM
Garage ceiling & door header Al Barb Interior Inspections 7 3/27/07 12:07 PM
Garage Door Safety...No Reverse...Advice Please gliebig Exterior Inspections 33 3/17/07 7:28 PM
Garage fire rated wall jlybolt Interior Inspections 3 6/18/06 6:21 PM
