The home owner has wired his bath exhaust fan with a lighting dimmer switch, the kind that is push-on, push-off and you can vary the current to a bulb. Besides being bad for the fan motor (or is it?), is there any danger to the homeowner? I'm thinking the switch could overheat?
John Kogel www.allsafehome.ca |
Marc Benz is a non-member guest and is in no way affiliated with InterNACHI or its members.
However if that is a motor speed control it may be ok depending on what namebrand the exhaust fan is and typically with motor rated speed controller it will slow down the fan motor a bit but when you slow down the fan you will really loose the performace pretty fast. Merci,Marc |
Pretty sure it's a light dimmer by the appearance of the knob and the on-off feature. Now I'm wondering if it can cause a fire by the motor drawing more current than the switch can handle.
The motor needs to be on its own switch, in my opinion.
I do not think it can cause a fire , but the motor may burn out. |
All that aside, why would anyone need a variable speed bathroom exhaust fan? Frank P. Newman Emerald City Inspections, LLC Dublin, GA |
| Poly being applied to Basement walls | dvalley | Interior Inspections | 40 | 11/24/09 10:49 PM |
| Options in selecting materials for basement construction | wdevries | Canadian Inspectors | 2 | 8/4/08 1:30 PM |
| Dimmer and Dumber | apolillo | Electrical Inspections | 8 | 2/17/07 9:22 AM |
| 3 way switches | cfuoco | Electrical Inspections | 4 | 2/1/06 8:00 PM |
