Attached are two photos with recorded temperatures of the buss at the time of yesterdays inspection. I hope the pictures are clear enough to recognize that the B phase buss is discolored and looks as though at one time it was overheated. This is the second home I have seen this on in the last two months.
The other picture is the SEC. Any others see much of this? |
yes, that panel will most likely need replacing.
Parts may not be readily available, replacing some parts in an old panel is bad maintenance anyway unless you have the means to check the current trip points on all of the old breakers. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
I see about a 20 degree rise (no other information available).
At this point I would not call anything? Did you do any other testing? Amperage/load? "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
I didn't take any amp readings. I did a thermal scan of each breaker and didn't see any issues. The only thing I called out on the panel was a mismatched breaker except that I added the thermal image and made my client aware of it.
What do you think caused it? Power surge? |
Those Murray/ITE/Seimens main breakers that are that style go bad on a regular basis. That style of main breaker was, is, and continues to be, junk (in my opinion). The one's in the red case seem to be the worst offenders. The recent "flat face" model seems to be okay so far, but both the red and black one's with the "bubble front" are not holding up in the field very well at all, in my experience.
How do you explain this one? This is the most discolored bus I've ever seen.
http://farm4.static.flickr.com/3269/...c9dcaa.jpg?v=0 Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
Gary,
Is that the temperature at the bus AFTER you set the "T-reflect"? If you haven't adjusted your T-reflect you may actually still have an overheating problem. The metal bar may be picking up cooler reflections. If there is a residue on the outside of the bus, the temps may be a bit more accurate. LEVEL 1 is an important class, especially for these types of applications. Good luck, let us know what happens. ************************************** Shawn Rowe, CMI HomeFirst Inspection Services, LLC - InfraRed Specialist (Level 1 & Building Science certified) - Code Certified Residential Building Inspector - Certified Master Inspector -- Serving NE Florida, St. Johns, Duval, Flagler, Putnam counties -- |
| Need help with main panel board buss bar | smcintire | Electrical Inspections | 63 | 1/8/08 5:55 PM |
| Split Buss CH panel w/Double tapped mains | gwilcox | Electrical Inspections | 5 | 7/18/07 7:14 AM |
| Discolored Walls at Registers | DSuelflow | Inspecting HVAC Systems | 10 | 11/23/06 12:48 PM |
| Split Buss | bwieczorek | Electrical Inspections | 4 | 8/16/06 5:30 PM |
