I did an inspection today on an older home that had a small guest house added to the back of the house that was detached from the main residence.
1. The wire that feeds to the subpanel is appears to be originally blue and looks to be discolored and brittle. I was unable to determine the case and I am assuming that it may have been from overheating? The hot lines are not colored black or red and the neutral is not colored white. 2. The subpanel is a Zylvania panel which I will write up on its own but the neutral and the grounding bus area shared and it is bonded to the panel and that also needs to be writing up correct? David Alvares Modesto, CA 95354 866-757-8480 |
Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
Thanks for the heads up Gerry
The panel bond may be OK in this detached building, but it's certainly prudent to have this verified.
In previous code cycles, when done properly, a detached building was allowed to have the same basic set-up as the service equipment - i.e. bonded neutrals and grounds, however, verifying this set-up as proper, would be well beyond the scope of a home inspection. You should also have had a grounding electrode at the detached building, and I don't see a GEC in that panel. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
| Difficult Chimneys | thance | Inspecting HVAC Systems | 2 | 1/29/08 9:16 PM |
| Help Determining Reportable Service Size | cbarrows | Electrical Inspections | 8 | 7/19/06 8:12 PM |
| Service Panel question for board sparkies | pbolliger | Electrical Inspections | 8 | 5/14/06 10:24 AM |
