Old 4/7/07, 8:25 AM
Default Disconect misplaced
Not exactly what I would call a smart move. How many would consider this a wet area?
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 4/7/07, 9:02 AM
Pierre Belarge Pierre Belarge is offline
Please Note: Pierre Belarge is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Disconect misplaced
Typically this would not be a wet location. As long as the equipment performs as designed, it will not be a problem, if a leak were to occur, it is not a wet location, just a leaky location.
Old 4/7/07, 9:16 AM
Richard W. Washington's Avatar
Richard W. Washington Richard W. Washington is offline
Mount that puppy on the wall or put a wood block underneath it at least. Yes, it is a safety issue and recommended to be repaired.
Richard W. Washington, owner
RW Home Inspections, Inc.
www.RWHOMEINSPECTIONS.com
Texas Real Estate Commission (TREC)
Professional Inspector License #7238
Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter
InterNACHI member since 2004
Based in Katy, serving Houston and all surrounding communities
Old 4/7/07, 10:11 AM
rromoser's Avatar
rromoser rromoser is offline
I would call it out for lack of working clearance in front of it. Then it doesn't need references to a wet location.
Old 4/7/07, 4:31 PM
Unmoderated Guest
Not a smart installation. At the same time is not nearly a wet location. No more so than under ANY bathroom or kitchen cabinet is a wet location.
Old 4/7/07, 6:00 PM
That is a NEMA 3R box rated for wet locations, it is just mounted wrong.
Misplaced Window jgilleland General Inspection Discussion 11 11/4/07 6:52 PM
