Justin Roberts Roberts Property Inspections PO Box 1972 Big Bear City, CA 92314 (909) 618-4697 BigBearHomeInspections.com |
| Need a home inspection in Wisconsin? Check out InterNACHI's listing of Wisconsin certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
It is the disconnect.
If it's between the meter and the panel then it's the service disconnect. The neutral should be bonded to the enclosure at that point. Since there are only three conductors on the load side of the disconnect the conduit would need to serve as the equipment grounding conductor. There should also be separation between the EGC's and neutrals at the sub panel.
| Main Panel vs Sub-Panel and main disconnect? | rbassett | Electrical Inspections | 11 | 10/24/09 6:16 PM |
| Exterior Service Disconnect Clearances? | rcramer | Electrical Inspections | 18 | 7/28/07 1:12 PM |
| 50 amp disconnect for 1600sf condo | kmccullough | Electrical Inspections | 5 | 4/10/07 8:49 PM |
| A/C Disconnect question | rslocum | Inspecting HVAC Systems | 15 | 9/21/06 12:16 AM |
| 100 Amp Meter, 200 Amp Disconnect | jweinberg | Electrical Inspections | 8 | 8/15/06 12:32 PM |
