Old 8/19/09, 8:50 PM
rbrady's Avatar
rbrady rbrady is offline
Please Note: rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Disconnect at the exterior
I am not sure where I got the idea that there is supposed to be a means of disconnecting the electrical service at the exterior, but I can not find anything to verify this.
Most of the panels are located at the exterior of the houses around here, so it is typicallly not an issue.
I thought the fire department wanted to be able to disconnect the electricity at the exterior.
Any thoughts would be appreciated.
Find an InterNACHI certified Kentucky Home Inspector (and anywhere else in North America)
Old 8/19/09, 8:57 PM
Joe Funderburk, CMI's Avatar
Default Re: Disconnect at the exterior
No requirement for an exterior disconnect.
There is a requirement for a disconnect in the service entrance panel (no matter where it is located) unless 6 or less breakers are there (you don't need a main breaker if 6 or less hand movements can turn off all the power).
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 8/19/09, 11:14 PM
Bob Elliott's Avatar
I almost never see a disconnect outside as that means someone like kids could be shutting you off at night.
Fire
Department can do what many do to work on the inside ,which is pull the meter head.
Old 8/20/09, 12:19 AM
bdoles2's Avatar
bdoles2 bdoles2 is offline
Many of our newer homes and multi family developments have the disconnect on the exterior.
i.e. this picture shows the exact situation for a 4 unit townhome.
Old 8/20/09, 12:47 AM
Attachment 31020
Must admit I do not understand why someone would want to have to go outset to reset the thing.
Old 8/20/09, 3:13 AM
Jim Port Jim Port is offline
Unmoderated Guest
One of the primary reason for the disconnect is because the panel inside is too far from the exterior. The NEC requires the length of unfused cable or conductors to be kept as short as practical. A distance is not clearly spelled out. It is up the the AHJ. Some areas only allow 5-6 feet of cable before the panel.
FD SOPS probably vary, but pulling a meter under load can be deadly. Safer to wait for the POCO to cut the feed at the ople or transformer.
Old 8/20/09, 9:49 AM
Fire
We see them everywhere here because is a requirement of the AHJ (in the city at least). They cite fire department requirements as mentioned above. Note also that pulling the meter under load can be hazardous and for larger services, the meter may be reading only a set of CTs and PTs so will not disconnect the service conductors.
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
Old 8/21/09, 1:07 AM
rbrady's Avatar
Thanks for the replies. I don't know where I got the idea that it is required, but when I tried to double check in my code books I couldn't find anything. I'll have to double check with the AHJ (or a local electrician) to see if it could be a local thing.
Old 8/21/09, 6:08 AM
ldapkus ldapkus is offline
Attachment 31020
That's where I see them most.
Old 8/21/09, 7:00 AM
David P. Valley's Avatar
Yes, but Single Family homes have them too.
As a matter of fact, my house has the SE disconnect outside, below the meter.
Old 8/22/09, 11:01 AM
Firstly, I get this asked alot on the "ROAD" and as Jim so nicely stated, the real concern is the amount of "unprotected" conductor that canbe run on the inside of the building [ 230.70(A)(1)]. Also since the nature of the "condo" experience is that you have individual units that get panels and since as stated earlier you can't meet the minimum safety standards on a conductor running wildly through the building with no protection. So they install a grouped set of disconnection means outside and then conductors on the load side of the disconnect are now feeders and they can be run through the building since they have protection on them.
Now I wont go into groupings and allowances on exterior run SE conductors if all outside and so on......just remember the above and you should be fine. Also remember that in some local jurisdictions they have a standard policy on the point of entry of service conductors where they say they are aware it can be outside or inside the nearest point but we want it outside, their rules their requirements are required to be followed in a given locality. Many take the following standard in many ways:
230.70 General.
Means shall be provided to disconnect all
conductors in a building or other structure from the service entrance
conductors.
(A) Location.
The service disconnecting means shall be
installed in accordance with 230.70(A)(1), (A)(2), and
(A)(3).
(1) Readily Accessible Location.
means shall be installed at a readily accessible location
either outside of a building or structure or inside nearest the
point of entrance of the service conductors.
Paul W. Abernathy
Moisture Management mcyr Exterior Inspections 15 9/8/08 12:11 PM
Exterior Service Disconnect Clearances? rcramer Electrical Inspections 18 7/28/07 1:12 PM
exterior main disconnect afrost Electrical Inspections 16 5/12/07 1:02 PM
