Old 10/8/09, 2:58 PM
Joshua L. Frederick Joshua L. Frederick is offline
Default Dishwasher outlet directly under unit
Comments?
As always, thanks for the replies.
Find an InterNACHI certified Oklahoma Home Inspector (and anywhere else in North America)
Old 10/8/09, 3:09 PM
Bob Elliott's Avatar
Default Re: Dishwasher outlet directly under unit
That cord sure does not look right and it appears to enter into the DW junction box from the rear.(bet there was not even a bushing)
Just out of curiosity, why did you remove the base plate?
Bad location though
and I would recommend GFCI even if the gurus say it is not needed in code.
Sure it is hard to reset but so is a spa tub GFCI in that you often need to remove the panel.
Another odd mention is the drain hose ,as it seems to maybe going down below the floor rather than to a sink T connection.
Old 10/8/09, 3:14 PM
I always do, so I can see stuff like this.
Old 10/8/09, 3:16 PM
Yeah good call as I would wonder myself if I did not see the shutoff under the basin.(I see they switched to flex)
Did drain hose go down also?
Old 10/8/09, 3:24 PM
Smile Re: Dishwasher outlet directly under unit
Yup, directly tapped into sewer line and leaking
Old 10/8/09, 3:41 PM
Bruce M. Graham, III's Avatar
Bruce M. Graham, III Bruce M. Graham, III is offline
looks like someone is using extension cord cable for permanent wiring
Bungalows to Mansions
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 10/8/09, 3:48 PM
They need to totally redo the DW connections.
Shame on you for going outside SOP you fool.
Old 10/9/09, 12:34 AM
Mark Thorman Mark Thorman is offline
Unmoderated Guest
Please Note: Mark Thorman is a non-member guest and is in no way affiliated with InterNACHI or its members.
I'm a big fan of removing the base plate espeicially on older units. Behind those two screws is the heart of the dishwasher.
www.MauiHomeInspections.com
980 Questions/Answers to the NHIE....Free! jbushart Legislation, Licensing & Legal Issues for Inspectors 50 4/20/08 2:26 AM
I smell rotten eggs. rbracewell Plumbing Inspections 18 1/15/07 5:09 PM
Hydrogen Bomb DISHWASHERS rspriggs Miscellaneous Discussion for Inspectors 8 8/3/06 5:55 PM
Exploding Dishwasher mbledsoe Plumbing Inspections 8 2/28/06 8:13 AM
