to switched garabage disposal outlet under sink. Yay or nay? Requirements for dishwashers to be hardwired?
Thanks in advance. |
| Need a home inspection in Arizona? Check out InterNACHI's listing of Arizona certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
It shouldn't be an issues as long as it meets manufacturer requirements and the cord insnt too long/sized accordingly.
They do make portable dishwashers.. Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
It's good. That cord takes care of the disconnect requirement.
Jeff Jeff Wicklander Corwick Home Services Join my business on Facebook
According to the NEC dishwashers are permitted to be cord and plug connected if such connections are permitted by the manufacturer of the dishwasher. As mentioned this also takes care of the disconnecting means. The requirments are quite restricitve. You cannot just cut off a section of extension cord and connect it to the unit. Is this dishwasher disposal combination connected to the same branch circuit?
Occasionally, the duplex receptacle (has been modified) under the sink is two separate circuits, each being dedicated for separate use like what you are talking about. You have to make an effort to determine if this is the case. One is hardwired for the DW and the other is on a totally separate circuit with the switch for the disposal. Takes a few extra seconds to determine.
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill |
| GE Dishwasher Recall | jbowman | Miscellaneous Discussion for Inspectors | 1 | 5/31/07 8:18 AM |
| GE Dishwasher Recall | bwiley | Interior Inspections | 1 | 5/16/07 4:14 PM |
| Maytag recalls dishwashers. 135 reports of dishwasher fires. | gromicko | Interior Inspections | 2 | 2/5/07 8:07 AM |
| I smell rotten eggs. | rbracewell | Plumbing Inspections | 22 | 1/15/07 4:09 PM |
| Exploding Dishwasher | mbledsoe | Plumbing Inspections | 8 | 2/28/06 7:13 AM |
