Is a dishwasher required to be on a switch (new construction)? Did a new home today and the dishwasher was not on a switch. Most homes are, yet I cannot find a reference in the IRC about it.
Thanks. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Many AHJ's required it back in the early 90's I think after a run of units caught fire due to a poor design or chaffed wire.
It was code I think in 2001 for york county but they told me that they did not enforce it then. I am seeing it on almost all new homes now though. Even though most units have a child override no one uses it so a switch is needed to keep kids from overcleaning the dishes. I don't write it up since all units I see have an override feature available and if a problem comes up with a model the CPSC will handle it. |
I don't think I've ever seen a dishwasher on a switched receptacle.
Must be a SC thing.......
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Scottsdale Home Inspectors, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
I have never seen it either...Maybe its plugged into the disposal recepticle?
jclark1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Definitely must be a SC thing.
smcarthur is a non-member guest and is in no way affiliated with InterNACHI or its members.
Fastened in place appliances are required to have a service disconnecting means. That can be a switch or a cord and plug arrangment. It's disign is to protect the person servicing the equipment, the same as the service disconnect on the A/C unit per NEC.
The reason for the switch is what Steve said.
A switched receptacle would be redundant since the only reason for the switch is a means of disconnect, not for controlling the applaince. |
In some areas the disconnect may also be a circuit breaker in the service panel provided a breaker lock is installed on the breaker.
I have seen them on a switch here, but that was simply because it was plugged into the switched receptacle meant for the disposal. |
I have never seen a switch for a dishwasher here either, other than the circuit breaker. As for needing the power turned off to service a dishwasher, every appliance repairperson I have ever seen working on a dishwasher (and I have seen a lot) wanted the power on to inspect all the circuits in the switches & controllers. Once they have located the problem they turn off the breaker if necessary for the repair. Jason Sieg, CMI Davison, MI NACHI05091399 Knowing the current condition, to make a wise decision.
President, Great Lakes-East Chapter Join NACHI Great Lakes - East Chapter http://mi.nachi.org/greatlakes-east/about.html ssieg@gfn.org |
Can you clarify your question Joe? Where do you normally see the switch? IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
| GE Dishwasher Recall | jbowman | Miscellaneous Discussion for Inspectors | 1 | 5/31/07 9:18 AM |
| GE Dishwasher Recall | bwiley | Interior Inspections | 1 | 5/16/07 5:14 PM |
| Maytag recalls dishwashers. 135 reports of dishwasher fires. | gromicko | Interior Inspections | 2 | 2/5/07 9:07 AM |
| Exploding Dishwasher | mbledsoe | Plumbing Inspections | 8 | 2/28/06 8:13 AM |
| 3 way switches | cfuoco | Electrical Inspections | 4 | 2/1/06 9:00 PM |
