Old 9/17/09, 10:18 PM
nbhi's Avatar
nbhi nbhi is offline
Default Distribution panel?
Here is a panel in a bedroom closet that protects the bedroom outlets and lighting. The bonding strap is no attached. It doesn't look right with the feed, 12/2 wire going to the lug. Any and all comments are welcomed.
"I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison
www.newbeginningshomeinspection.com
Find an InterNACHI certified Texas Home Inspector (and anywhere else in North America)
Old 9/17/09, 10:24 PM
Default Re: Distribution panel?
A SUB-PANEL, or REMOTE DISTRIBUTION PANEL, is merely an extension of the main service panel. Since the neutrals are bonded to the grounding wires in the MAIN SERVICE PANEL, the grounding wires (bare) and the neutral wires (white) should never be connected in any manner beyond the main panel. However, the grounding wires should be bonded to the sub-panel. Also there should be a fourth wire--attached to the ground buss in the main panel and connected to the separate, bonded ground buss in the sub-panel.
Old 9/17/09, 10:49 PM
Jeff Rema's Avatar
Jeff Rema Jeff Rema is offline
Please Note: Jeff Rema is a non-member guest and is in no way affiliated with InterNACHI or its members.
1) Equipment ground is not bonded to the panel
2) The lug that connects 2 grounds is not rated for 2 wires
3) No AFCI protection? or is it at the main panel?
4) Are you sure that is not 14/2?
5) Appears to be a waste of a panel for the purpose it serves. Best to be a junction box. Why even use a OCPD when there is one in the main (we hope)
6) Located in a clothes closet is a no-no.
Old 9/17/09, 10:56 PM
Christopher Currins's Avatar
Also,
Most, if not all, modern building safety practices do not allow electrical service panels or distribution (sub) panels to be installed in clothes closet. Over current devices should not be located in the vicinity of easily ignitable material, such as in clothes closets.
Examples of locations where combustible materials may be stored are linen closets, paper storage closets, and clothes closets.
The panel location may also limit the required working space at the panel.
Christopher Currins
Certified, Licensed
Proudly serving the Illinois Metro-East
Illinois Home Inspector
Top 5 Tasks for January
Old 9/18/09, 10:56 AM
GARY L. RUSK GARY L. RUSK is offline
Gary is the circuit on an overcurrent protective device in the main panel, if not it should be. If it is why is it going to a sub panel in a closet? I would have installed a junction box instead of a sub panel.
Gary
Old 9/18/09, 1:23 PM
Jeffrey R. Pope's Avatar
This is a hack job. Recommend removal of the panel and "circuit" by a qualified electrician.
There's no telling what other issues exist with the balance of the installation.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 9/18/09, 2:54 PM
Tim Spargo's Avatar
Utility Co's will "make mention" (at minimum) for EMF issues when a panel is on exterior of bedroom as well.
Have seen a few times over the years where AHJ allowed install and utility said "Really?" when meter was to be installed.
Tim Spargo
Spec Rite Inspections
661-317-5770
National Electrical Code Information and Discussion jtedesco1 Electrical Inspections 50 6/15/10 8:28 PM
Sub distribution panel 'over qualified' ? lfoster Electrical Inspections 7 4/12/09 8:56 AM
Electrical for Dummies mcyr Electrical Inspections 16 6/9/08 10:59 PM
Bad electrical problem Pest Guy Electrical Inspections 4 1/20/06 10:26 PM
