How do I write up exterior rated wiring located inside of the panel. Is it ok??? It terminates outside to the sub for the AC. Also there are long tails inserted into the breakers..do I recommend that they be trimmed or leave them be???
| Find an InterNACHI certified Missouri Home Inspector (and anywhere else in North America) |
I don't see a problem with it the gray wire. I don't see any plastic beneath the breaker screws. Do you really want to ask someone to hire an electrician to trim 1/8" off the end of a wire? While you might do it differently, that doesn't mean the electrician did it wrong.
What's the basis of your idea that this is a problem? “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com Last edited by jfunderburk; 10/30/09 at 12:08 PM.. |
If it were "exterior rated wiring," there would be no issue. However, this appears to be a cord & plug assembly that was altered/modified for this application, in which case, I would call it out as improper wiring.
There is nothing wrong with the black wire you have an arrow drawn to, provided it is sized correctly for the breaker.
That looks like UF cable to me. It just looks like it was not stripped down to the conductor insulation. |
thanks for the opinions guys...your help is awesome!!!
Cord wouldn't have solid conductors would it?
Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
You're correct Chuck, cord would be stranded. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Is the neutral at the bottom of the bus bar oxidized or burt? Perhaps it's just a shadow.
| Sarah Palin for President. | gromicko | Miscellaneous Discussion for Inspectors | 240 | 9/2/08 12:21 PM |
| Michigan home inspector licensing meeting on July 23, 2008. | gromicko | Legislation, Licensing & Legal Issues for Inspectors | 125 | 8/10/08 8:23 PM |
| Mention voltage drop? | dbucknavich | Electrical Inspections | 18 | 6/18/08 7:58 PM |
