Old 4/18/09, 6:18 PM
Rick Vollmer Rick Vollmer is offline
Please Note: Rick Vollmer is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Do I need special electrical work for this?
I have just discovered that my house is built over a natural stream. I have dug out the crawl space and inserted a sump pump. However, the sump pump will only work on one cord. I have read the instructions and that said to plug in one (can not remember what it was call) then plug the other into the first one. I get nothing. When I hook up just the one cord into the extension cord, it will pump. But I cannot get it to run in the automatic mode. I am using a heavy duty extension cord for right now, and it is pluged into a standard (not GFI) box, which is in my crawl space..
Sorry if this is posted in the wrong forum. Any assistance would be appreicated, even if you tell me where to post this question.....
Many thanks in advance..
Find an InterNACHI certified Idaho Home Inspector (and anywhere else in North America)
Old 4/18/09, 7:58 PM
Michael Roberson's Avatar
Michael Roberson Michael Roberson is online now
Default Re: Do I need special electrical work for this?
Not a problem, glad to help.
What you have is a sump with a float switch right? The cord running directly to the pump is hard wired, and the plug with the male/female is connected to a float. (correct me if im wrong) Inside the float is a switch that senses when it is up/on or down/off. It will take some adjusting of the direction and length of cord to get it right with the water level. I DO NOT recommend plugging it into an extension cord. Attached is a pic of a sump extension cord I PERSONALLY took from a house sump system. Recommend its own circuit, GFCI. You can get a GFCI breaker, so you don't have to go in the crawl space if it trips
Any further questions you may ask them or email me at
Pioneer@homeinspectorpro.com
Old 4/18/09, 8:02 PM
Does this Sump Pump intend to stay in it current location? If so using the Extention Cord is not an option because it is taking the place of fixed wiring. Install a properly done circuit for this application and install a GFCI receptacle to which you will plug in the PUMPS factor listed cord for a proper installation.
Paul W. Abernathy
Old 4/18/09, 8:12 PM
A video that may help you understand how it works.
http://www.youtube.com/watch?v=8ozrH...eature=related
Old 4/19/09, 10:39 AM
Man I love Videos to explain things....
Paul W. Abernathy
Old 4/23/09, 5:44 PM
mvanek mvanek is offline
Send a message via AIM to mvanek
Please Note: mvanek is a non-member guest and is in no way affiliated with InterNACHI or its members.
They come with 5, 10, 15, 20, and 25-foot-long power cords. Extension cords shouldn't be used with sump pumps. Maybe with a longer cord on the pump you can reach a outlet. Then you can install an GFCI Breaker on that circut if possible.
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
You Asked for it, Mr. Tedesco. Here it is.... jbushart Miscellaneous Discussion for Inspectors 0 1/23/08 4:24 PM
Dwelling and Commercial Electrical Equipment jtedesco1 Electrical Inspections 4 1/10/08 6:46 AM
Electrical Safety Principles pabernathy Electrical Inspections 8 1/1/07 1:13 PM
Electrical Safety Information jtedesco1 Electrical Inspections 0 2/19/06 1:48 AM
