Do we need an electrician to fix this? There is no other work to be done in the panel or the rest of the houes. I could say "Amateur workmanship on some of the wiring" or si this a more serious condition? Any fire hazard here? So how serious is potential loss of grounding on a branch circuit?
John Kogel www.allsafehome.ca |
I would not say that you needed an electrician to fix this. Add a length of wire to this and properly terminate it in the ground buss.
The hazard is if there was a fault the path back to the panel is compromised and may not trip the breaker. This could lead to a fire. Along with the wire not properly terminated on the correct buss the screw heads contact with the wire is poor and the paint was not removed from where the wire contacts the case. |
I personally always recommend an electrician for repairs and any upgrades especially for any work inside a panel. If the homeowner decides to do this themselves and get their yoyo knocked into their watchpocket or worse I want to be on record as saying "hire a licensed electrician" in my report. Most people do NOT know what they are doing when it comes to electrical, even home inspectors. Just that environment is a dangerous place to be putting your hands. Just because something is seemingly small or minor does not mean it can't kill you. Always take any scenario to the next logical conclusion and ask yourself....What if?
What they do after I have told them what should be done is up to them but I am secure in knowing I told them to do it the right way. |
In addition to that ground wire non-compliantly terminated under that deck screw, there's other weird stuff going on there. I see a piece of flex armor at the top of the pic, inside the panel, which is just plain weird. There's no compliantly terminated flex that could ever be inside the panel.
Hey, those are square d breakers aren't they required to be double tapped?
Just kidding, Thought I would start a electrical argument I haven't seen before. Mark Jones Allmark Home Inspection Services Inc. Serving all of Northern Illinois, Vernon Hills, Libertyville, Gurnee, Fox Lake, Round Lake Phone: 847 651 2053 E-Mail: AllmarkInspect@aol.com www.AllmarkHomeInspection.com |
[quote=Jim Port]I would not say that you needed an electrician to fix this. Add a length of wire to this and properly terminate it in the ground buss.
quote] I agree...and if you need financial advice, ask a panhandler. "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin |
What about that #10 on the 10 Amp breaker? All that sheathing inside the box and the wire on the left, the splice with no wire nut and taped all the way across. Other than that, it's a real cherry.
| This House Met Code. | jbushart | Electrical Inspections | 88 | 1/16/08 12:29 PM |
| Repairs made by a LICENCED electrician | cduphily | Electrical Inspections | 45 | 1/13/08 3:09 PM |
| Electrician signs off 'ganged neutrals'...now what? | mgault | Electrical Inspections | 16 | 6/2/07 11:09 PM |
| Electrician or handyman repair? | srowe | Electrical Inspections | 8 | 1/4/07 9:21 AM |
