Old 4/17/11, 6:50 PM
James L. Keilson's Avatar
James L. Keilson James L. Keilson is offline
Send a message via ICQ to jkeilson
Default Do You Call This Out ?
OK the main incoming SEC was done correctly other than the hole needs to be sealed up for water and insects protection. My question is that as you can see the cable company came and ran a boatload of cable through the sec sleeve? What do you think?
Jim
Maryland Home Inspection Services Inc.
www.MarylandHomeInspectionServices.com
State of Maryland License# 31141
Virginia License#3380 000468
National Association Of Certified Home Inspectors ID: NACHI10101807
International Association of Certified Indoor Air Consultants (IAC2). Certification # IAC2-02-0919
Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C.
Need a home inspection in Montana? Check out InterNACHI's listing of Montana certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/17/11, 6:56 PM
Wayne B. Wilson's Avatar
Default Re: Do You Call This Out ?
I would think it should not be in the same run . I know telephone is not allowed to do it
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Old 4/17/11, 7:16 PM
Robert Meier's Avatar
Since they're all cables in that sleeve I don't see an issue.
Old 4/17/11, 8:57 PM
James E. Braun, CMI's Avatar
If you run a network cable, such as for internet, right along side of an electrical line it will disrupt frequencies into the network cable slowing speeds down. Networking cables will pick up the alternate current field around the electrical line. The two cables should not be in the wall cavity, but can be on the opposite sides of a wall stud. I pretty sure on the older coax you could run them in the same conduit, but I imagine with the new HD televisions this might cause a problem with clarity.
Condo Bob was once a TV cable guy, maybe he can answer the question about coax.
Braun Inspection Consultants
Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
Old 4/18/11, 10:30 PM
agallatin agallatin is offline
This does not look like a proffetional job . What doesthe rest of the wiring look like ?
galaxyhomeinspections.com
An amateur built the Ark !
Professionals built the Titanic !
Old 4/18/11, 10:51 PM
Bob Elliott's Avatar
Not allowed
Old 4/19/11, 4:53 AM
Originally Posted by belliott View Post
Not allowed
Are you saying that this is a code issue or just poor design?
Old 4/19/11, 7:03 AM
Cable wires should always go through their own sleeves.
When running cable, it is best to follow a few simple rules:
  • Always use more cable than you need. Leave plenty of slack.
  • Test every part of a network as you install it. Even if it is brand new, it may have problems that will be difficult to isolate later.
  • Stay at least 3 feet away from fluorescent light boxes and other sources of electrical interference.
  • If it is necessary to run cable across the floor, cover the cable with cable protectors.
  • Label both ends of each cable.
  • Use cable ties (not tape) to keep cables in the same location together.
Old 4/19/11, 9:41 AM
Home inspectors are not code inspectors so as soon as home inspectors understand that, the less chance of them be humiliated on the job.
Old 4/19/11, 7:19 PM
John E. Mullarkey John E. Mullarkey is offline
James is correct, the technical term is Parasitic oscillations. You can observe/hear them by driving next to High tension lines with your AM radio turned on to a weaker station. That buzzing sound is similar to effect of running cable lines next to SEC.
Old 4/19/11, 7:49 PM
Not allowed by the cable companies and one call gets it removed.
Old 4/19/11, 9:02 PM
So how would you write this one up?
Cell Phone Do not call #'s bjones5 Canadian Inspectors 10 1/31/09 12:17 PM
Last Call for INSPECTVUE SOFTWARE DISCOUNT $845.00 includes Tax...... jwatts1 Inspection Hardware, Software & Publications 4 8/8/07 10:47 AM
Last call for 2006 pricing for Inspection Management Systems from TheScheduleCenter gromicko Miscellaneous Discussion for Inspectors 1 12/20/06 8:22 AM
