Old 9/7/07, 9:03 AM
msylvester's Avatar
msylvester msylvester is offline
Send a message via AIM to msylvester
Default Do you open stab-lock panels?
How many of you if any open federal Pacific stab-lock panels?
In my case I never do because of the way the breakers overlap the panel cover.
Does anyone finagle the cover off to actually check the wiring?
In my case I just explain the facts about the panel and explain why I don't pull the dead fronts off of them.
I'm always curious of what I would find if anything.
Mark Sylvester
P.I. Home Inspection Services
www.pihomeinspection.com
mark@pihomeinspection.com
Old 9/7/07, 9:21 AM
wsiegel wsiegel is offline
Default Re: Do you open stab-lock panels?
Unless I can definetly tell that the breakers are loose, I open them all up.
Old 9/7/07, 9:31 AM
msylvester's Avatar
Do you ever trip the breakers?
Mark Sylvester
Old 9/7/07, 9:34 AM
Greg Bell's Avatar
Greg Bell Greg Bell is offline
I almost always open an FP. I never open a Zinsco.
Greg Bell
Titusville, Fl
02111507
Serving Central Florida
Old 9/7/07, 9:41 AM
msylvester's Avatar
I have tripped the breaker several times while taking the panel covers off so I tend not to pull them. I should also explain I always find these panel in condos tucked up under the kitchen cabinets with very little room if any to move the cover up and over the breakers. The picture is of my latest one that had other problems as you can see.
Mark Sylvester
Old 9/7/07, 10:38 AM
Jeffrey R. Pope's Avatar
There are less problems with opening Zinsco's. Man-up Greg
I open all covers unless there are obvious safety concerns. I occasionally trip breakers, but that's just the way that it goes. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 9/7/07, 10:39 AM
Barry Adair's Avatar
Every one when I can reasonably access.
Greg,
Why not Zinsco?
This one was accessed though the inside of a cabinet about a foot inside a 12" duct chase and near the end of my arm. The panel had been built into the chase back in '67-'72 when the kitchen was remodeled. No way was I going to try and remove the cover. I wondered who added the GFCI?
Client: "What needs to be done?"
Me: "Consult a carpenter and an electrician for the cost to relocate to an accessible location.
Client: "Why a carpenter?"
Me: "Have you ever seen an electrician tear into a wall to gain access?"
Client: "NO?"
Me: "The only thing worse is when a plumber does it."
They got the picture
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 9/7/07, 11:08 AM
Jim Port Jim Port is offline
Unmoderated Guest
If you were to open the panel up due to the design of the buss stab it is quite possible that some breakers will just fall out of the panel. At this point you could see any hot spots or deterioration of the buss.
Old 9/7/07, 11:40 AM
Charley L. Bottger's Avatar
If I did not open FP panels I would not be opening very many at all 75% of all panels in my area are FP
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 9/7/07, 1:15 PM
While perhaps bordering on a violation of the SOPs does anyone just trip the main breaker(s) before pulling the cover off of such panels? I would think that would be preferable to not inspecting the panel at all.
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
Old 9/7/07, 1:25 PM
Not in an open forum and how would this violate SOP?
Maybe exceed, but violate???
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 9/7/07, 2:02 PM
David P. Valley's Avatar
I open all FPE panel dead fronts unless obvious safety issues are present.
They're aren't many electrical panels that get by me without being fully accessed.
We don't have Zinsco's here in Massachusetts.
Old 9/7/07, 2:56 PM
Your 'exceed' may be more correct. I guess I was referring to...
2.7.II. The inspector is not required to:
D. Operate overcurrent devices
In any event I think it would be a good, safe practice any time a panel looks or 'feels' suspicious.
Frank P. Newman
Dublin, GA
Old 9/8/07, 3:10 PM
lfoster's Avatar
lfoster lfoster is offline
We usually open all panels, the exception is FP and it depends on how accessible it is.
On tripping the main before looking, what if Grandma is upstairs in an iron lung?
I don't unplug / turn off anything.
Think of safety first !
Old 9/8/07, 3:18 PM
Michael Larson's Avatar
Originally Posted by lfoster
..........On tripping the main before looking, what if Grandma is upstairs in an iron lung? .........
Man, I hate when that happens
I did manage to get somone mad at me when I accidently dumped the circuit his computer was on. It was a reporter writing an article who had not backed up recently. oops! sorry 'bout that
Let's just say he wasn't happy about having to rewrite it. Everyone seems to learn the hard way about backing up frequently.
Help. What is the correct way to report a breaker that is too big. gromicko Electrical Inspections 77 5/10/12 6:13 PM
Distribution panels bking Electrical Inspections 2 3/11/07 10:29 AM
Electric Radiant Ceiling Panels bbernier Canadian Inspectors 4 2/15/07 1:22 PM
Old electrical panels? ysoltis Electrical Inspections 3 1/14/06 11:00 AM
