Quiz time. Do you see anything wrong with the electrical system?
| Need a home inspection in Maryland? Check out InterNACHI's listing of Maryland certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Photo #1-maybe
Photo #2-yes Photo#3-Looks OK from the photo. What do you see wrong? |
Other than the high-efficiency louvered cooling cover, no.
Good call Jeffrey
Did they bury the mast and SEC behind the siding, too?
My thought too.
no loop
not good access in case of fire I couldn't see a shut off tab for the 200 amp breaker |
gfitzgerald is a non-member guest and is in no way affiliated with InterNACHI or its members.
a little close to the window
No good access in case of a fire. What is wrong with shutting off the main breaker? Attempting to pull a meter under load could have deadly consequences. Access to the socket would be a power company issue. The shutoff on the main breaker even says ON. What else is needed? Last edited by Jim Port; 5/9/10 at 6:39 PM.. |
Are the drip loops actually ON the roof?
The one on the left looks as though it may well be, the other appears to be headed that way.
jrider is a non-member guest and is in no way affiliated with InterNACHI or its members.
Does the main shut off have some heat damage to it? Without zooming in, looks like it is melted a little.
1. Only power service drop conductors shall be permitted be attached to a service mast. 2. No ready access. Meter box cannot be opened. 3. Does not appear be a main service panel. The lay out of the breaker do not look right. (What does the inside look like?) |
3- With the arrangement of the main (extra slot below) it almost appears like this is a three phase panel. |
| Help. What is the correct way to report a breaker that is too big. | gromicko | Electrical Inspections | 77 | 5/10/12 6:13 PM |
| Evaluating your home's wiring system | mcyr | Electrical Inspections | 0 | 12/30/09 1:31 PM |
| Make $50.00 More Profit per Inspection with Septic Tanks | ebeahm1 | Ancillary Inspection Services & Additional Topics | 6 | 8/20/09 1:38 PM |
| Hey Electricians... Can you help by proofing this new course? | gromicko | Electrical Inspections | 69 | 10/15/08 6:14 AM |
