New home, did not see where the panel was bonded, am I missing something?
Hi to all,
Tim I could do with a larger picture but it appears that the panel bond (s) are the 2 green screws on the neutral bridge at the very top of the panel. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
ccbrands1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
what are the bare copper wires at the top left of the panel? do they run from the neutral bus to the plumbing system? bigger pic would be nice. |
That doesn't look like service equipment to me. . .
Why are you looking for a bond in a sub-panel? BTW- The bond hole is the large (1/4") hole in the center of that bar between the neutral bars. Not the small green screws. |
Agreed....and the hole in the middle of the buss is not bonded...because in fact it is a sub panel based on its MLO setup.
I have to say....I simply HATE when electricians leave labeled romex in the boxes.....to me it is unprofessional......fine for the rough in...but then when you come to label the panel...remove the freakin things.....nasty if you ask me. Paul W. Abernathy |
See, now I do like to leave small pieces of NM sheath as wire labels. Much smaller then in the pic though. Typically about 1" long. And usually though only if it is a flush panel. That or I leave the sheath a bit long inside the panel and label right there.
If it is a surface panel I label the wire with a NEW Sharpie just before it enters the panel. I do NOT like to reply simply on the panel directory alone. Even at the complete end of the job. See, even good electricians have differing opinions. |
lol........Oh thats just sloppy Peter....
I am a freak about being neat in my panels....things like sloppy labels and old romex and so on....makes me insane.... Paul W. Abernathy |
ofcourse they would say I am insane anyway...so go figure !
Paul W. Abernathy |
I agree. Like I said, the pieces I might leave are way smaller and neater than that panel.
I like them because no matter who messes with, and rearranges the panel, the circuits themselves are always labeled. Not just the breakers. |
Pierre Belarge is a non-member guest and is in no way affiliated with InterNACHI or its members.
Nothing we did not already suspect. |
| Does Anyone See A Panel Bond Here? | pdickerson | Electrical Inspections | 14 | 10/24/07 11:40 AM |
| Jacuzzi Bond wire was cut. Why ? | ccooper | Electrical Inspections | 35 | 1/30/07 2:45 PM |
| Panel bond | dmacy | Electrical Inspections | 12 | 10/19/06 10:19 PM |
| E&O vs. Performance Bond in PA | byocum | Miscellaneous Discussion for Inspectors | 3 | 5/30/06 10:39 PM |
