Notice the bottom breaker. They lead to a 220v electric clothes dryer?
How does it work? Maybe you can explain. Don Peterson, CMI AmeriDream Home Inspections Inc. NYS License: 16000014560 |
Drier is really two 120 products in one box that normaly take the current from both sides of the 240 volt feed to the home (120 from one side and 120 from the other)
If you wire both drier feeds to only one side of the 240 line (which is wrong) you are unbalancing the home by alot. This does not work for all driers rlb |
removed due to wrong info
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 Last edited by bking; 2/18/07 at 5:29 PM.. |
if both legs of the circuit are on the same phase, how can the voltage potential be 240v
I think he made a typo there, and that would not considerably "unbalance the home" .
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 Last edited by bking; 2/18/07 at 5:30 PM.. |
This would NOT overload the neutral. If it were on two separate breakers on the same phase it would. Being that it is on the SAME individual single-pole breaker the neutral cannot possibly carry more than that single breaker's rating.
It is physically and electrically impossible for this circuit to be providing 240v. Period. I would make a guess and say they ran typical 10/3 to a dryer location, then changed the circuit to a 120v gas dryer. Instead of just using one hot they used both for some strange reason. Then possibly they changed back to an electric unit and did not change the circuit back over. |
This has to be a 120v dryer (Gas) . The blower of a regular 240v dryer would still go but the element would not heat up. They are connected L/L across the ungrounded leads. In this case that would produce zero volts.
It is an electric dryer, the drum worked, but not the heat. The tenant stated that they bought a breaker and installed it.
He bought the wrong breaker. A 2 pole will probably fix it. There seems to be plenty of space. I would still recomend they get a real electrician in there to replace the breaker and be sure the handy tenant didn't screw up anything else.
If this is intended to be wired for the dryer, this is what should be in place.
Sorry I did not get your PM until late......seems like you have it taken care of here......any additional questions just let me know...I am off...my sons birthday...the big 9 this week...
Paul W. Abernathy |
Me: "grumble, grumble, grumble..." |
Customer: "It's on a breaker. So, what's the problem?"
Me: Sir, it is very complicated. Paul W. Abernathy |
Boy did I shoot myself in the foot on this one
You did not tell us that the dryer did not work and that someone had replaced the breaker!! And I did not ask for additional information to give a proper answer My mind went to the dual voltage dryers that one sees in small apartments and RV I am bleeding bad on this one rlb |
| Help. What is the correct way to report a breaker that is too big. | gromicko | Electrical Inspections | 77 | 5/10/12 6:13 PM |
| Dryer sheets potential hazard | badair | Miscellaneous Discussion for Inspectors | 15 | 7/9/11 2:39 PM |
| What is a 'condenser' dryer ?? | rcooke | Canadian Inspectors | 9 | 9/9/07 7:02 PM |
| Dryer lint filter | senomoto | Miscellaneous Discussion for Inspectors | 6 | 5/14/06 10:01 AM |
