NEC 312.5 C states
Where cable (NM) is used, each cable shall be secured to the cabinet, cutout box, or meter socket enclosure. If the box is older (say 25 years) and all cables come into one or two opening how and what would you report? Would you recommend it be repaired? Basically what its saying is all wires should come into the main panel individually. For many older installations they are grouped togeather. SInce this is no longer an accepted practice, do you write it up at all, and what would you say. Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net Last edited by sfogarty; 1/13/11 at 7:43 PM.. |
| Need a home inspection in New Jersey? Check out InterNACHI's listing of New Jersey certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Good question. There is an exception to the section that you've posted but it's highly restrictive and was not likely part of the NEC 25 years ago. From what I've been told there are parts of this country where the exception to 312.5(C) is violated everyday and the practice is considered acceptable. Usually an exterior panel with all of the cables running in through a 2" chase nipple in the back of the panel.
774 Manor Road Staten Island, NY 10314 718-514-3393 |
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
| Using your report writer as a marketing tool | sramos | Inspection Hardware, Software & Publications | 3 | 4/17/09 9:24 PM |
| New Report Upload Technology | cdemsky | Miscellaneous Discussion for Inspectors | 49 | 5/1/07 10:19 AM |
