or not?
No real inspection question here but a friend of mine has an open neutral between outlets in his garage. Would it be advisable to just run a saw kerf between them, push in a strand of THNN, tape, float and call it a day or bad move? John Onofrey Licensed Professional Inspector Houston Home Inspection Houston Home Inspector www.texasinspectors.net John Onofrey President, Grail Media, LLC "Effortless Email Marketing" www.homehintsenews.com 2007 INACHI Inventions and Innovations Award Winner Free! Inspector Email Marketing trial click here |
bkelly1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Thhn needs to be in an approved conduit. Or wireway. He could use wiremold.
What about solid conductor?
jclark1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
you don't want to run a neutral and a hot in separate conduits.
John,
Beside is being something that is not allowed, I would not advise him to do that method. The best thing to do is try to determine where the break in the neutral first. It is very rare to have a break in a neutral within the wall cavity itself so the problem may be in a junction above the garage so I would have him check that as well. If your buddy plans on opening up the wall between the two receptacles anyway....would be better off just pulling a new NM Cable and notching out the studs ( protecting with nail plates afterwards ) patching and mudding and would take about the same time frame. This would be an acceptacle method to fix the problem. However do not rule out a possible splice joint somewhere in in a junction between the two outlets.....might not be but never rule out anything as it sounds like a joint that has come loose....also pull BOTH receptacles OFF the circuit in question ( de-energize ) and do a verified conti. test between the Black and White ( if romex ) by twisting one ends Black and white together and verify cont. from the other open end......may just be a receptacle issue. Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
Perfect. Thanks all.
