Old 4/22/09, 10:12 PM
Bruce A. King's Avatar
Default Does FHA require
Assuming an FHA loan and FHA knew the house had 3-prong outlets with no ground.
Would FHA require GFCI protection on 3-prong outlets that have no ground or would the stickers that indicate "no ground" be acceptable?
The house in question is in SC.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Find an InterNACHI certified Florida Home Inspector (and anywhere else in North America)
Old 4/22/09, 10:25 PM
Default Re: Does FHA require
not sure about the FHA but I can expect that they would want it to be compliant and free of issues. Someone installing 3 prong plugs on a non-grounded system is misleading the consumer. So with that said to me this is a clear code (minimum safety standard issue ) in that you either provide the ground to make it a grounded receptacle, install a GFCI on the circuit and label the 3 prong as GFCI Protected and No Equipment Ground or they replace the receptacles with 2 prong plugs.
All of those options are acceptable.....but alas I did not answer your FHA question did I....I would not sign a load if I knew of issues, what I dont know would not effect my loan giving process...but if I knew...i would expect them to correct it as it is a common DIY mistake.
But ofcourse you knew of all that I spoke....I could not help it....lol
Paul W. Abernathy
Old 4/23/09, 9:52 AM
James E. Braun, CMI's Avatar
The last FHA checklist I ever saw had no mentions of requirements of outlets, but I imagine FHA requirements are different in each state.
Ontario to Require Fire Sprinklers in New Condos and Apartments mkyriacou Canadian Inspectors 1 7/18/08 10:18 PM
Does NJ require a state Lic? jlomonaco Miscellaneous Discussion for Inspectors 4 3/19/08 10:50 PM
Does Canada, like Colorado, require front & back license plates? gromicko Canadian Inspectors 9 10/12/06 3:24 PM
