Old 4/16/07, 7:53 PM
John J. Passailaigue, Jr.'s Avatar
John J. Passailaigue, Jr. John J. Passailaigue, Jr. is offline
Send a message via AIM to jpassailaigue
Default This doesn't look correct
Fellow on lookers and cohorts,
Looked at a new construction home today and when entering the electrical panel in the garage, I saw something I didn't like. In professional opinions, what does it look like to you? What say ye oh wise ones?
John J. Passailaigue Jr.
NACHI05062580
Auburn Home Inspection
Auburn, Alabama
WAR EAGLE!
Old 4/16/07, 8:36 PM
Marc D. Shunk's Avatar
Banned
Default Re: This doesn't look correct
What, in particular, didn't you like?
Old 4/16/07, 8:45 PM
The white wire that is wrapped under the main power wires. Does it need to be contacting the main wires comming into the panel?
NACHI05062580
Auburn, Alabama
WAR EAGLE!
Old 4/16/07, 9:27 PM
mschild mschild is offline
It looks like they were not consistent with breaker types (manufacturers). Can't tell without reading them.
Neutral wire is running a bit close to the main lines. It is a bit of a sloppy spaghetti mess. Could have been a home-owner special install!?
Mark and Tammy Schild
Freedom Home Inspections
Grand Blanc, MI
http://freedom Home Inspections.4t.com
Old 4/16/07, 9:47 PM
New Construction home
NACHI05062580
Auburn, Alabama
WAR EAGLE!
Unmoderated Guest
Looks like all GE to me.
This is a sub-panel. The neutrals from those GFCBs/AFCBs need to get over to the neutral bar.
They could have put them on the other side of the panel for neatness.
Old 4/16/07, 10:00 PM
Banned
No, it doesn't need to be, but that's a workmanship issue. No hazard.
Old 4/16/07, 10:38 PM
psiposs psiposs is offline
Send a message via Yahoo to psiposs
How close do you think those wires are from the pole? Its sloppy but it looks ok to me.
Peter Siposs
Absolute Home Inspections
Home, Mold, IAQ, Radon, & Lead Based Paint
Liberty Lake, WA
Serving Eastern WA & Northern ID
Nachi# 05100181
peter@absolute-home-inspections.com
Old 4/16/07, 10:44 PM
The only wire I see that has white paint on it is going to a power rail. It might just be a sloppy painter since this does not seem to be intentionally "identified". Where is the service disconnect and is this being fed with 4 wires? Where is the main bonding jumper? We need a better picture of the panel and the enclosure feeding this one to really evaluate it.
Old 4/16/07, 10:47 PM
Banned
I see 4 wires, don't you? Appears to be fed with SER.
Old 4/16/07, 10:58 PM
Yup, I pasted to my picture program and blew it up. I see the ground.
Correct connect at Furnace tmartens Plumbing Inspections 2 5/1/07 10:33 PM
First to answer this question substantially correct wins a NACHI Beam. $109 value. gromicko Miscellaneous Discussion for Inspectors 28 1/30/07 5:30 PM
First to answer this question substantially correct wins a NACHI Beam. $109 value. gromicko Miscellaneous Discussion for Inspectors 18 1/22/07 9:55 PM
Is this correct cpennick Electrical Inspections 4 6/15/06 11:15 PM
Help with correct term? cvowell Plumbing Inspections 11 6/1/06 4:15 PM
