I don't see what the T slots are good for. The description states 15A, 120V.
When I look at 406.7 it really looks to me like the 2-20 was a 240v plug
Two flat prongs would be 220V. One flat, one upright would be 110V, 20 A, so you couldn't accidently plug the low voltage device into the 220 outlet, right? Now if you want to produce a Polarized receptacle, like the Leviton unit in Greg's picture, why would you give it double t-slots? Polarized 20A would only want one t-slot for each plug-in. Like the red one there. Last edited by jkogel; 8/19/08 at 12:33 AM.. |
You guys need to throw out everything you think you know about modern plug configurations out the window. Again I state, really old 110V stuff had two sideways prongs. How do I know? I work in really old houses every day.
Justin D. Schlueter is a non-member guest and is in no way affiliated with InterNACHI or its members.
Marc,
What kind of appliance did you see have the two prong tandem plug on? I know I have seen many of the old two prong T slot receptacles, but I guess no one except antique collectors have appliances with those plugs? I thought I had an old Hubbell two prong plug laying around with one prong tandem and one prong straight, thing was labeled 15 A 125 V. The older stuff WAS weird. Another wierd thing is that the old T slot receptacles had dual ratings, something like 15 A 125 V and 10 A 250 V. This modern remake does not. Also note that it says NON UL. So perhaps the only real purpose for a receptacle like this would be in another country (maybe in south America or Mexico.) Where there isn't as stingent as listing standards. Just my guesses. |
Anyway, the modern 6-15R and 6-20R receptacles are rated at 250 VAC, and look like this pic. |
Marc Benz is a non-member guest and is in no way affiliated with InterNACHI or its members.
Typically with that kind of repectale it is used on older two wire circuit sans ground wire.
I ran into like that pretty often with some olderhome like that arrangement and alot of " handy peoples " make a common mistake with replaceing the receptale and don't relized that you can have two choice one is have GFCI at first receptale before downstream of that circuit and labled " NO equiment grounding " or stay with modern receptale without grounding slot verison. Merci,Marc |
| Selling my GMC Yukon.. | krea | Miscellaneous Discussion for Inspectors | 4 | 7/8/07 9:56 PM |
| Selling to NACHI Memebers | ekartal5 | Miscellaneous Discussion for Inspectors | 50 | 2/26/06 1:11 AM |
