How many code violations can you spot?
Fogarty Inspection Services Group of Knoxville TN Sean Fogarty Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.homeinspectionknoxville.com |
| Find an InterNACHI certified Nebraska Home Inspector (and anywhere else in North America) |
Possibly, but it shouldn't be inside the panel regardless of what it's for.
IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net Last edited by jpope; 10/6/09 at 12:20 PM.. Reason: oops |
I hope you had a type-o. I asked the question with sarcasm. Most doorebel transformer around here are under the home or in a coat closet.
Jeff,
You mean outside right? Bungalows to Mansions Professional Inspection Services, LLC dba 1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
No, Bruce, he means shouldn't InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
The transformer should be mounted on the outside of the panel or it isn't grounded.
Picture 4 (of the main lugs is fuzzy) what is your question there? Don't interfere with anything in the Constitution. That must be maintained, for it is the only safeguard of our liberties. Abraham Lincoln www.qualityhomeinspectionsfl.com |
Jeff Rema is a non-member guest and is in no way affiliated with InterNACHI or its members.
725.55 of the NEC normally addressed this situation but the 2008 NEC made significant changes in numbering. Anyone know where it is now?
Picture 4 has a broken plastic isolation ears and neutral conductors (in addition to be jammed under one lug screw) in close proximity to one of the legs.
Sloppy amateur work. I is r eye -litric-gal specialist.. |
I posted the pics just for humor. The panel was a major mess. I just summed it up by saying there were several issues, and a licensced electrician needed to come out and further inspect, and repair or replace as needed.
| Doorbell Transformer | Rafael | Electrical Inspections | 3 | 6/24/09 11:45 AM |
| Is this a booby trap.... or an old doorbell? | jfordyce | General Inspection Discussion | 21 | 4/17/09 11:25 PM |
| Doorbell double-taps? | jkogel | Electrical Inspections | 10 | 7/21/08 1:13 AM |
| Hot Doorbell | lagudo | Electrical Inspections | 11 | 10/13/07 5:05 PM |
| Doorbell transformer double tap | bsmith | Electrical Inspections | 11 | 4/17/06 1:48 PM |
