[quote]David Cook "In some areas the ESA will allow a soft (doorbell transformer) to be under the same screw as a hard wire."[quote/]
I haven't heard this before, but it makes sense. I always report the doorbell double-tap, but often wonder if it requires rework in a case where there are no other issues. My thinking is that it was allowed at the time of construction, and has been that way for 20 years in many cases. Any objections? John Kogel ww.allsafehome.ca |
The second picture shows the tap on a double 15A breaker, breaker services two general room circuits, outlets and lights. Any objections?
My favorite one below, double-tap and a solid Al pigtail with an ordinary wire nut to lengthen the copper neutrals . (That other wire is a flexible cord from the fireplace fan which is nearby, who needs a junction box?) Last edited by jkogel; 7/20/08 at 4:54 PM.. |
Bruce Erny is a non-member guest and is in no way affiliated with InterNACHI or its members.
That is a code violation. Breaker not rated for 2 wires. An Issue?, you decide.
At least your transformers are mounted on the outside of the panel. I aways find them laying on the inside.
Scott A. Figert www.sfigert.com www.nachi.org NACHI #06042595 Figert Building Inspection, Ltd. (419) 399-4472 Office & Home Sweet Home |
syared is a non-member guest and is in no way affiliated with InterNACHI or its members.
In my area I find this consistantly on old and NEW construction. It a double tap, but it's also allowed by local authorites.
I doubt you will find a breaker listed for anything smaller than 14. What is the wire size of a doorbell transformer lead?
If it is really 16 or 18 you can't connect it to the breaker in any way. You have to pigtail it.
The breaker lists the wire sizes it can successfully terminate. If the wire is too small they are saying it may not be a good connection particularly if you have 2 wires. Pigtailing a compliant wire increases the chance you will get a good connection.
| Double taps | Mike Parks | Electrical Inspections | 11 | 5/28/06 2:52 PM |
| Doorbell transformer double tap | bsmith | Electrical Inspections | 11 | 4/17/06 1:48 PM |
| Double Taps | rwand1 | Canadian Inspectors | 30 | 3/29/06 8:16 PM |
| Double Taps | psmothers | Electrical Inspections | 3 | 3/9/06 11:04 PM |
