| Electrical Contains discussions about electrical systems. This includes outlets, panels, wiring, et cetera. |
Is there a problem with there being two GFCI protected outlets on the same circuit ? the lower bathroom has a GFCI but it trips the one in the upper bathroom when tested. I have gotten mixed messages on this being a hazard or just a hassel for the owner.
Sounds like a belt and suspenders solutions.
tom |
Mike Whitt is a non-member guest and is in no way affiliated with InterNACHI or its members.
There is no hazard or "violation" with this type of redundancy, however, it may become a nuisance.
This is also an indication of electrical work performed by a non qualified individual.
ah, I see where that could happen. I guess you could label them GFCI or NO GFCI, but then you'd have to teach your guys to read!
I always listen for the click from another location just in case.
Sometimes when I had a GFCI downstream of another GFCI, I would only get the local one to trip. The speed, and construction, isolated the fault and kept the upstream one working. As HI's you just have to report that it's protected(the circuit/receptacle), as an electrician/home owner I would want to fix it.
tom |
I find this occaisionally. I inform the client of the potential for confusion, but I don't call it out as a defect for repair. I also verbally inform them that a licensed electrician likely would not have done this.
| GFCI Safety Notice | rcooke | Electrical | 1 | 10/30/07 12:29 PM |
| Double tapped GFCI breaker | sspradling | Electrical | 6 | 12/9/06 10:51 AM |
| Double GFCI protection. | dmacy | Electrical | 8 | 7/26/06 7:31 AM |
| AFCI Questions and Answers - Mike Holt | pabernathy | Electrical | 0 | 7/7/06 12:24 PM |
| Can an AFCI offer GFCI protection | gbeaumont | Electrical | 19 | 7/6/06 11:45 PM |
