Old 4/29/10, 8:39 PM
Dale G. Ganfield Dale G. Ganfield is offline
Default Double Lug on Ground bus and no crimp sleeves
Can someone confirm that the double conductors under the lugs on the ground bus are incorrect and that the twisted conductors should have a crimp sleeve and then one conductor only under the lug. With the number of available lugs I am not sure why the conductors were doubled. Photos are attached. Thanks
Need a home inspection in Missouri? Check out InterNACHI's listing of Missouri certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/29/10, 9:33 PM
Jim Port Jim Port is offline
Unmoderated Guest
Default Re: Double Lug on Ground bus and no crimp sleeves
Most ground busses are listed for use with multiple grounding conductors. Check the label inside the panel for sizes, materials. Stranded conductors do not need anything added before they are terminated in the buss.
Old 4/29/10, 10:03 PM
Thanks. I looked at the label. (2) #14 on grounding bus allowed.
Old 4/30/10, 8:40 PM
Andrew Cox Andrew Cox is offline
Multiple ground conductors may be allowed, but is that the best practice? I think if there are open lugs, they should be used... there's no reason to double or triple up on conductors if there are open lugs.
I realize that is not for me to decide, and is not necessarily an issue to call out, but it does make me look harder for other shortcuts in the panel...
Andy Cox
http://www.CoxInspections.com
Kissimmee, FL
You’re Your Own Job Security.
Old 5/1/10, 10:57 AM
Unmoderated Guest
I would not consider using a panel part as it was designed to be a shortcut. Leaving other buss holes open also allows for future circuits to be added without affecting any other part of the panel wiring. Heck, if this is a service panel the use of the auxullary ground bar would show extra effort and cost vs using the neutral buss for both grounded and grounding conductors.
Old 5/2/10, 6:55 PM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
I found these today.
double-lug-ground-bus-and-no-crimp-sleeves-048.jpg   double-lug-ground-bus-and-no-crimp-sleeves-046.jpg
Mid America Property Inspections, Inc.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
KS-Radon Cert.# KS-MS-0035
KS-Termite Cert. # 18933
M0-Termite Cert. # N 5033
Old 5/2/10, 7:01 PM
Now why would you call it a short cut if the manufacturer allows the installation to be done. If Eaton Cutler Hammer has a panel tested that allowed multiple equipment grounding conductors to be terminated under a single screw of a UL approved terminal buss then why is it a short cut or a problem?
Again what one person may fine as a shortcut another finds as thrifty, all under the eye of perfectly compliant. As an inspector I try to leave personal preferences out of my inspection process and inspect to compliance.
Paul W. Abernathy
Old 5/2/10, 7:02 PM
Now see....these are some GREAT examples of non-compliant installations and yet another reason why even meeting the minimum standards of the National Electrical Code are critical starting points.
Great Pics !
Paul W. Abernathy
Old 5/3/10, 8:20 AM
Originally Posted by pabernathy View Post
As an inspector I try to leave personal preferences out of my inspection process...
Good advice...
Larry Kage, CMI
231 929 3525
