Old 4/14/06, 8:50 AM
Steven Brewster Steven Brewster is offline
Please Note: Steven Brewster is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Double Lugging
This panel is beneath the meter and should be the Service Equipment/Main disconnect. I know double lugging is prohobited and the feeder cable should have been connected to a breaker/disconnect at this panel but need the code violation/ref. indicating the deficiency. Thanks.
Old 4/14/06, 9:25 AM
Jeffrey R. Pope's Avatar
Default Re: Double Lugging
110.14 Electrical Connections. Terminals for more than one conductor and terminals used to connect aluminum shall be so identified.
Not to mention the fact, that those conductors have no OCPD. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 4/14/06, 9:29 AM
Thanks Jeff,
The panel on the interior is a Walker (fuse type) with a 100 amp disconnect. It has some issues as well. I can't believe this service upgrade was not inspected and the feeder for the interior installed on a 100 amp breaker at the SE.
Old 4/14/06, 5:06 PM
apolillo's Avatar
apolillo apolillo is offline
Please Note: apolillo is a non-member guest and is in no way affiliated with InterNACHI or its members.
Also, from the picture, it looks like the AL conductor has been trimmed to allow both wires to fit.........
Anatol
Old 4/14/06, 8:54 PM
I agree. . .
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 4/14/06, 9:49 PM
Yep I also agree....and about 50% or less of the threads on that neutral strand is actually in the lug.....
Paul W. Abernathy
Old 4/15/06, 12:04 AM
Maybe the Home Depot should start handling the Ilsco (or similar) line of splicing blocks. They can be a bit spendy for the insulated connectors but it is a simple solution for these ugly double taps.
Double Tap Questions jkogel Electrical Inspections 6 6/28/07 9:46 PM
Double lugging or not? jlybolt Electrical Inspections 7 6/4/06 11:21 PM
Doorbell transformer double tap bsmith Electrical Inspections 11 4/17/06 12:48 PM
Double Taps rwand1 Canadian Inspectors 39 3/29/06 7:16 PM
Double lugging neutrals? JohnH515 Electrical Inspections 17 3/3/06 10:05 AM
