Old 9/20/06, 10:23 PM
Peter Doane's Avatar
Default double main breaker help
200amp meter base. 4/0 alum service to Bulldog "Push-o-matic" panel. Two buss bars in the panel that had 100amp breakers one each side. (One on the left, one on the right.) Question: Is the structure limited to 100amps or do we combine the two buss bars for 200amp service?
Thanks for anyones input.
Peter Doane
NACHI ID# 05120681
Old 9/20/06, 10:27 PM
Default Re: double main breaker help
Peter,
Does the 4/0 conductor terminate in a common LUG for both buss bars?
If so...based on the 4/0AL I would call it a 200A Service.....if it is as stated above.....both bars give the panel a capacity of 100A each...and the overall rating is 200A.....
Did the panel itself have a rating on it?
Paul W. Abernathy
Old 9/20/06, 10:35 PM
Yes, the 4/0 service was at a common lug. then it split into two rows of breakers with the 100amp breakers at the top.. So 200amp is correct then?
Peter Doane
NACHI ID# 05120681
Old 9/21/06, 8:35 AM
Yes...that is correct !
Paul W. Abernathy
Arching Causes Main Breaker To Trip? msylvester Electrical Inspections 10 10/22/07 3:57 PM
Double pole breaker, metal showing between sections lfoster Electrical Inspections 2 9/6/07 12:25 PM
Double tap at main lugs gmathias Electrical Inspections 4 8/8/07 7:20 PM
Double Tapped Breaker tjohnson3 Electrical Inspections 8 4/20/07 9:04 AM
