Old 6/20/07, 9:33 PM
nbhi's Avatar
nbhi nbhi is offline
Default double panels
The box on the left is grounded at the plumbing. The box on the right, there is no grounding what so ever. Is the grounding coming from the conduit that connects the panels?
Attachment 12492
Thanks
"I have not failed, I have just found a 1000's way's that didn't work" Thomas Edison
www.newbeginningshomeinspection.com
Old 6/21/07, 12:07 AM
Bob Elliott's Avatar
Default Re: double panels
Your website has something wrong with it ,and there may be some spy ware site in its place.
Old 6/21/07, 4:51 AM
nbhi's Avatar
Robert
Don't know what happened, but I change my signature and now its fixed.
Thanks
Old 6/21/07, 9:14 AM
Jeffrey R. Pope's Avatar
The panels are bonded at the meter bases. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 6/21/07, 1:23 PM
nbhi's Avatar
Jeff
This is find then correct?
Thanks
Old 6/21/07, 2:29 PM
Looks good from my house
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 6/22/07, 5:35 AM
Pierre Belarge Pierre Belarge is offline
Please Note: Pierre Belarge is a non-member guest and is in no way affiliated with InterNACHI or its members.
The grounding of each service disconnect has to be brought into each service disconnecting means. One should not bring the GEC to one service disconnect and then leave the other without a GEC.
250.24(A)
Old 6/22/07, 12:03 PM
Pierre, with all due respect you only need one ground at each "service".
250.24 Grounding Service-Supplied Alternating-Current Systems.
(A) System Grounding Connections. A premises wiring system supplied by a grounded ac service shall have a grounding electrode conductor connected to the grounded service conductor, at each service, in accordance with 250.24(A)(1) through (A)(5).
(1) General. The connection shall be made at any accessible point from the load end of the service drop or service lateral to and including the terminal or bus to which the grounded service conductor is connected at the service disconnecting means.
In fact it does not need to enter the service disconnect enclosures at all. It could be up on the mast at the service point. A silly choice but legal. In the meter base is more common.
Old 6/23/07, 6:58 AM
nbhi's Avatar
So Greg what you are saying is that, each panel needs to have its own ground? Meaning, ground rod and at the plumbing, correct?
Old 6/23/07, 11:30 AM
Each "service" needs a grounding electrode system but you only have one service in your example. You can have up to six disconnects on a service but you only need one grounding electrode conductor. "made at any accessible point from the load end of the service drop or service lateral to and including the terminal or bus to which the grounded service conductor is connected at the service disconnecting means".
I suppose there are other intrepretations but you will need to explain them to me and rationalize the things in red above (on post .
Double Tap Questions jkogel Electrical Inspections 6 6/28/07 9:46 PM
Distribution panels bking Electrical Inspections 2 3/11/07 10:29 AM
Double Tap! wward Electrical Inspections 12 2/22/07 5:39 PM
Double Taps rwand1 Canadian Inspectors 39 3/29/06 7:16 PM
FPE Panel - Do you open them up? menser Electrical Inspections 11 2/7/06 6:31 PM
