Old 4/25/07, 6:42 PM
Al D. Bolt Al D. Bolt is offline
Default Double pole breaker with one wire.
This electric furnace in a manufactured home has only one wire on the disconnect breakers. Seems unusual to me, is it OK?
Old 4/25/07, 9:24 PM
Marc D. Shunk's Avatar
Banned
Default Re: Double pole breaker with one wire.
Looks like that furnace has had a fair amount of field modification.
Old 4/25/07, 10:02 PM
rromoser's Avatar
rromoser rromoser is offline
I agree with Marc. Perhaps the empty side of the 50 amp. breaker has gone bad and the apparent splice below it bypasses that phase to complete the 240v circuit.
Old 4/25/07, 11:34 PM
David A. Andersen's Avatar
The breaker looks like it is turned off.
Looks like one bank of heaters have been abandoned.
Old 4/26/07, 2:24 AM
jbreazeale jbreazeale is offline
Please Note: jbreazeale is a non-member guest and is in no way affiliated with InterNACHI or its members.
It has definitely been wired around the breaker for some reason. The installation is not safe. There will always be 120v to ground.
Old 5/1/07, 2:47 PM
Thanks for the input.
Al
Double pole breaker, metal showing between sections lfoster Electrical Inspections 2 9/6/07 1:25 PM
Nice Report on AL Wire Terminations - Enjoy pabernathy Electrical Inspections 0 7/2/07 1:35 PM
Double Tapped Breaker tjohnson3 Electrical Inspections 8 4/20/07 10:04 AM
Ground wire in neutral bar, neutral to breaker, hot to ground? rmc3inspection Electrical Inspections 4 8/1/06 10:44 AM
