Old 8/20/09, 3:24 PM
Richard M. Ross's Avatar
Richard M. Ross Richard M. Ross is offline
Send a message via Yahoo to rross2 Send a message via Skype™ to rross2
Default Double tap 30 amp, 240 for dryer dryer
I remember this was talked about before, but I can't find it. Home has two laundry rooms; garage and 2nd floor each with a dryer 240 outlet. Instead of separate breakers for each dryer 240 outlet, they did a double tap on a 30 amp breaker. The breaker is designed for two leads. Is this ok?
Richard Ross
Accurate Home Inspections of America, LLC
Cape Coral, FL 33914
239-271-8499 Office
239-271-8499 Mobile
407-358-5376 FAX
Find an InterNACHI certified Oregon Home Inspector (and anywhere else in North America)
Old 8/20/09, 4:32 PM
David P. OKeefe's Avatar
David P. OKeefe David P. OKeefe is offline
Default Re: Double tap 30 amp, 240 for dryer dryer
I was thinking no right up until you said the breaker was made for two wires. Now I'm not sure. Glad I could help.
David
InterNACHI #08051301
NYS Lic. #16000038229
NYS DEC Cert # T4865884
518-505-8305
HouseAbout Home Inspections
HouseAbout on Facebook
NY Capital Region Chapter InterNACHI
Old 8/20/09, 4:41 PM
Is it similar to this?
If run one at a time it may work but possible nuisance tripping.
Larry Kage, CMI
231 929 3525
Old 8/20/09, 7:31 PM
Marcel Gratton's Avatar
I would say the circuit is overloaded and may / will cause nuisance tripping. Recommend two separate circuits.
On The Level Inspection
Gatineau, Québec
Old 8/20/09, 8:54 PM
Mark Thorman Mark Thorman is offline
Unmoderated Guest
Please Note: Mark Thorman is a non-member guest and is in no way affiliated with InterNACHI or its members.
Check the amps required for both dryers. Most dryers require 20+amps so in that case the answer would be no.
www.MauiHomeInspections.com
Old 8/23/09, 10:09 PM
Givne that we are not doin gcode inspections, if the wire to each receptacle is rated for the full 30 amps, the arrangement itself may not be hazardous. The biggest problem will be nuscience tripping if they try to run both dryers at the same time. It is very possible that the situation came to be becuase a previous owner decided they wanted the dryer in a new location instead of where orginally installed, so they never intanded to use both locations. If that is the case, the old locations should have been disconnected.
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
Dryer Vent Repair Delaware County nhagarty Ancillary Inspection Services & Additional Topics 1 1/31/11 8:03 AM
Dryer Vent Cleaning Philadelphia PA nhagarty Ancillary Inspection Services & Additional Topics 0 1/11/09 12:24 PM
Dryer Vent Cleaning Montgomery County PA nhagarty Ancillary Inspection Services & Additional Topics 0 1/11/09 12:23 PM
Dryer Vent Cleaning Delaware County PA nhagarty Ancillary Inspection Services & Additional Topics 0 1/11/09 12:22 PM
What is a 'condenser' dryer ?? rcooke Canadian Inspectors 9 9/9/07 7:02 PM
