Old 5/12/11, 8:57 PM
Joshua L. Frederick Joshua L. Frederick is online now
Default Double tap at meter?
I know I posted something similar to this a while back, but anyway, here goes again. Main house panel 100 amps and detached garage panel also with 100 amp panel which also had a main breaker and was not wired up like a distribution panel. The house panel did not have breaker and/or any wiring to feed garage panel. So this means they obviously double tapped meter socket, no? They're normally not double lugged, right? I'm assuming this is incorrect. 1959 house that was flipped. House panel was updated/newer and the garage panel was older (20+).
Need a home inspection in New Jersey? Check out InterNACHI's listing of New Jersey certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/12/11, 9:03 PM
Robert Meier's Avatar
Default Re: Double tap at meter?
There's only one conduit coming out the bottom of the meter so where can this tap actually be?
Old 5/12/11, 9:07 PM
That's what I'm asking.
Old 5/12/11, 10:11 PM
Jeffrey R. Pope's Avatar
Any pictures of the interior of the service panel?
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 5/12/11, 11:52 PM
agallatin agallatin is offline
Maybe the garage is feeding the house panel !
galaxyhomeinspections.com
An amateur built the Ark !
Professionals built the Titanic !
Old 5/13/11, 12:42 AM
Bob Elliott's Avatar
If I really wanted to know badly enough I might accidentally trip the main breaker in the house.
Interesting panel behind that meter though.
Old 5/13/11, 4:24 AM
First pic house panel installed on adjacent wall from meter (50 amp breaker on left is stove). Second pic garage panel (didn't have a good interior pic).
double-tap-meter-20721-buckskin-defiance-068.jpg   double-tap-meter-20721-buckskin-defiance-035.jpg
Old 5/13/11, 7:10 AM
The painter did a nice job of making everything off-white.
Old 5/13/11, 8:40 AM
Joe Funderburk, CMI's Avatar
Something is definitely wrong. If there are 2 main panels, the one in the detached garage being one of them, then the garage panel should have a main breaker or be no more than 6 throws to turn off the power there. Otherwise, if the garage is wired as a distribution panel and not a service entrance panel, there there should be a feeder at the house main panel with OCP.
Regardless, there should be a grounding electrode at the detached building. Was there?
It appears service comes into the meter from the mast head, goes through the wall to one panel, and underground to the detached building. That would be 2 main panels and if so, then there is a problem with the detached building panel's lack of a main breaker.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 5/13/11, 9:35 AM
Jim Port Jim Port is offline
Unmoderated Guest
If this is the case, another issue would be that the services are not grouped as required.
Old 5/13/11, 9:37 AM
It did have a main breaker. What do you mean "grouped"?
Old 5/13/11, 9:47 AM
Since the garage panel has a main breaker, is this set up acceptable? How would you report?
Old 5/13/11, 10:29 AM
Unmoderated Guest
Grouped as in co-located or next to each other. For this case there would be a means of disconnect either outside near the meter or the house panel with a main breaker and a disconnect next to that for the garage.
Old 5/13/11, 10:40 AM
Was there a GES at the garage? If not, it's wrong. You don't have to detail every single issue. Point out the concerns and refer it to a competent, licensed sparky.
Theodore Roosevelt
Joe Funderburk, CMI
Old 5/13/11, 11:01 AM
How did you determine that the garage panel was not fed from the service panel?
The garage panel has its own disconnect - this is required and proper. The garage panel should also include a grounding electrode (as a detached building) as Joe mentioned. In addition, the garage panel should include a 4-wire feed (H+H+N+G). Grounds and neutrals should be separated, neutrals isolated. The exception would be a 3-wire feed with no other conductive connections between buildings. It's beyond the scope of the HI to determine that.
The service equipment looks fine (except for the paint) and there appears to be at least one 240V circuit, capable of feeding the garage panel.
Jeff Pope
Santa Clarita CA
(661) 212-0738
gas meter dyoung General Inspection Discussion 20 3/1/10 3:25 PM
Gas Meter dyoung AskNACHI.org Inspection Questions Forum 7 2/25/10 9:06 PM
CPSC -----> Recall on electric meter panels pbolliger Electrical Inspections 0 10/15/09 11:23 PM
Double tap on Meter ehyde Electrical Inspections 7 1/12/08 2:52 PM
