ekartal6 is a non-member guest and is in no way affiliated with InterNACHI or its members.
40 year old Square D 100 amp service equipment panel. Is the double tap on the left allowed? I don't have any records that indicate this panel allows for a double tap.
Thanks |
That IS a "clamp" type Sq D breaker. It is fine.
Thanks Speedy. Are you referring to the gold clamp?
Scott Schultz is a non-member guest and is in no way affiliated with InterNACHI or its members.
erol,
you did pick up that solid strand aluminum wire right? |
Which one do you figure is the aluminum. The 3d breaker down looks more like tinned copper to me. Aluminum will usually have TW insulation, not that pulp stuff.
You have improperly marked white wires on some of those breakers.
| Double tapping question | mroe | Electrical Inspections | 17 | 8/30/07 9:32 AM |
| Double Tap Questions | jkogel | Electrical Inspections | 6 | 6/28/07 10:46 PM |
| Double Taps... Here we go again | rwand1 | Canadian Inspectors | 4 | 10/28/06 4:55 PM |
| Rule of Thumb A/C sizing question from Practice Exam | gliebig | Inspecting HVAC Systems | 9 | 5/25/06 2:38 AM |
