If this double-tap arrangement is wrong, and it can't be right to use stranded and solid wire under one screw, can it?
Could this be fixed with a pigtail and a wire nut? How is this done professionally? (Yes, this is a Canadian Federal Pioneer panel, fairly new.) John Kogel www.allsafehome.ca Last edited by jkogel; 1/22/09 at 12:20 AM.. |
Professionally you would install a separate breaker.
1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
As far as I know, Federal Pioneer breakers are still rated for only one conductor under the breaker's terminal. What you have pictured is non-compliant, in my professional opinion. I do disagree, however, that the corrective measure is to dedicate a circuit to the chime transformer. That would be absurd, or wasteful at least. The real corrective action normally involves pigtailing a single conductor to the breaker and making a wirenut splice in the panel. Oops! Sorry. Canada here.... a 'marette' splice.
My step-dad gave me a whole box of old timer "marettes" that were threaded brass rings with setscrews and plastic caps that screwed down over them, boy what a pain to wire a house with those! The electrician had a good laugh when he came to install the service. I can think of another way to install the tranformer - to attach it to a handy junction box in the garage or the attic. Easier to replace that way. |
Splices and Taps. No unnecessary splices or taps shall be made within or on a luminaire. FPN: For approved means of making connections, see 110.14. |
| Nice Report on AL Wire Terminations - Enjoy | pabernathy | Electrical Inspections | 0 | 7/2/07 12:35 PM |
| Double Tapped Breaker | tjohnson3 | Electrical Inspections | 8 | 4/20/07 9:04 AM |
| Double tapped GFCI breaker | sspradling | Electrical Inspections | 6 | 12/9/06 10:51 AM |
| Doorbell transformer double tap | bsmith | Electrical Inspections | 11 | 4/17/06 12:48 PM |
