Old 12/7/06, 9:18 PM
sspradling sspradling is offline
Please Note: sspradling is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Double tapped GFCI breaker
Is there a problem double tapping a Square D GFCI breaker in the panel? Both wires are the same size. Today was the first time I've seen it done. Thanks in advance.
Stu
Old 12/7/06, 9:30 PM
Jeffrey R. Pope's Avatar
Default Re: Double tapped GFCI breaker
That would depend. Was the breaker rated for two conductors? If not, then it's a problem. . .
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 12/7/06, 9:50 PM
All the other breakers had the m shaped clips under the screw, but this one had a little chip broken out of the breaker body right next to the screw, was in a tight spot with other wires so I couldn't see the clip, both wires were on the same side.. I'm whining now. I'll recommend replacement because of the chip and be done with it. Thanks.
Stu
Old 12/8/06, 7:08 AM
Pigtailing the wires and bringing one conductor to the breaker may be sufficient. ...for the double tap not the broken breaker.
Larry Kage, CMI
231 929 3525
Old 12/8/06, 8:56 AM
Stuart,
You are not whining...you are learning.....a very good thing. And yes, if the breaker is damaged recommend it be replaced as the trama that caused the breaker to actually " Break " could have caused internal damage....can't say tha for sure but anytime an inspector notices damage to a breaker or so on in a panel....refer to it in your report and defer the liability.
Lawyers sometimes can make mountains out of mole hills....if given the chance.
Paul W. Abernathy
Old 12/8/06, 10:41 AM
Sometimes????
Abraham Lincoln
Old 12/9/06, 10:51 AM
Originally Posted by bwiley
Sometimes????
lol...Good Point.......
Paul W. Abernathy
AFCI Questions and Answers - Mike Holt pabernathy Electrical Inspections 7 4/16/12 9:51 PM
double GFCI protection rperkerewicz Electrical Inspections 11 10/9/07 6:06 PM
Double pole breaker, metal showing between sections lfoster Electrical Inspections 2 9/6/07 12:25 PM
GFCI breaker abolt Electrical Inspections 24 6/21/07 2:06 PM
Double Tapped Breaker tjohnson3 Electrical Inspections 8 4/20/07 9:04 AM
