Old 6/23/09, 11:46 AM
wstafford's Avatar
wstafford wstafford is offline
Default double tapped with wire nuts
I found a 20 amp breaker with a single 12ga. wire about 4 inches long connected to two 14ga. wires with wire nuts branching out to their individual circuits. Any feedback? Thanks
Will R. Stafford
Promised Land Construction & Home Inspection
Home Inspector from Wilmington to Jacksonville NC and surrounding areas.
www.plchomeinspection.com
Jacksonville Home Inspector
Wilmington Home Inspector
Find an InterNACHI certified Indiana Home Inspector (and anywhere else in North America)
Old 6/23/09, 12:10 PM
James F. McKee's Avatar
Default Re: double tapped with wire nuts
that should be a 15 amp breaker Will....imo
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 6/23/09, 12:14 PM
Jeffrey R. Pope's Avatar
That would not be considered a "double tap," in fact, if the breaker was sized appropriately (which it is not), it's perfectly acceptable.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 6/23/09, 1:00 PM
rmaday's Avatar
rmaday rmaday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
It would be considered a "pig-tail".
And like Jeff sadi, it's fine (provided the breaker is right szie)
Old 6/23/09, 1:43 PM
Joe Farsetta's Avatar
Joe Farsetta Joe Farsetta is offline
ESOP Committee Member
Correct-a-mundo
Old 6/23/09, 2:51 PM
wstafford's Avatar
Thanks guys
Will R. Stafford
Old 6/23/09, 10:36 PM
Agreed it is not a double tap....However, lets not over look the fact it is (2) 14 awgs technically on a 20A breaker with no additional details. so if you are asking if it is a double tap...no...if you are asking if the method of installation is correct in your example....NO.......as others have said recommend to them to change the 20A breaker to a 15A breaker.
So the real issue here is not the pigtail....it is what the pigtail connects to
Paul W. Abernathy
Old 6/24/09, 9:02 AM
This is a method some people use to get around the fact that the breaker allows only one conductor. The concept i sperfectly legal. However, the comments about the breaker size are, of course, correct.
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
Double tapped breaker shand General Inspection Discussion 9 6/7/09 1:50 PM
What's this video worth? jtedesco1 Inspection Education & Training 5 4/18/08 9:24 AM
Nice Report on AL Wire Terminations - Enjoy pabernathy Electrical Inspections 0 7/2/07 12:35 PM
Double Tapped Breaker tjohnson3 Electrical Inspections 8 4/20/07 9:04 AM
