Old 8/13/10, 2:42 PM
Steve A. Rinner Steve A. Rinner is offline
Default Double tapping main
Is it ever ok to double tap the main lug in a panel. I alway believed this was never allowed. I have a sellers electrician telling me it is ok. something about a 35 foot rule and something about crimping? The tap goes to the AC disconnect.
Any help would be appreciated.
Thanks
Steve Rinner
GLH Home Inspections
Norwalk, Ohio
Need a home inspection in Maine? Check out InterNACHI's listing of Maine certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/13/10, 2:45 PM
James H. Bushart's Avatar
Default Re: Double tapping main
Have the seller's electrician refer you to the local code that allows it.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 8/13/10, 3:15 PM
Jeffrey R. Pope's Avatar
Very unlikely that this is a proper connection. Do you have any puctures?
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 8/13/10, 7:13 PM
Bruce A. King's Avatar
I know someone who had a meter panel burn up due to loose double taps. The power company came out and said "not our problem, not our box, call an electrican".
She had it fixed by an electrician, the bill was quite high, they had to make a few trips, a cable was too short, it was below 15 degrees etc etc.
The owner ended up filing a complaint with the power company and getting reimbursed.
Here is why they had to pay:
1. Your name is on the box.
2. You put the anti-tamper tag on it so you must have approved the wiring.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 8/13/10, 11:43 PM
photo. hope this helps
Steve Rinner
Norwalk, Ohio
Old 8/14/10, 6:09 AM
Robert Meier's Avatar
100% violation for using a lug listed for one conductor with two conductors. Also the use of a white conductor as an ungrounded conductor is a violation as well.
110.14 Electrical Connections.
Because of different characteristics of dissimilar metals, devices such as pressure terminal or pressure splicing connectors and soldering lugs shall be identified for the material of the conductor and shall be properly installed and used. Conductors of dissimilar metals shall not be intermixed in a terminal or splicing connector where physical contact occurs between dissimilar conductors (such as copper and aluminum, copper and copper-clad aluminum, or aluminum and copper-clad aluminum), unless the device is identified for the purpose and conditions of use. Materials such as solder, fluxes, inhibitors, and compounds, where employed, shall be suitable for the use and shall be of a type that will not adversely affect the conductors, installation, or equipment.
FPN: Many terminations and equipment are marked with a tightening torque.
(A) Terminals. Connection of conductors to terminal parts shall ensure a thoroughly good connection without damaging the conductors and shall be made by means of pressure connectors (including set-screw type), solder lugs, or splices to flexible leads. Connection by means of wire-binding screws or studs and nuts that have upturned lugs or the equivalent shall be permitted for 10 AWG or smaller conductors.
Terminals for more than one conductor and terminals used to connect aluminum shall be so identified.
Old 8/14/10, 9:18 AM
Jim Port Jim Port is offline
Unmoderated Guest
RM has posted the correct cite for this violation.
It is possible to employ the tap rules to do what was asked about. however, this is not the correct way to do it.
Old 8/14/10, 9:51 AM
It would be nice to post a picture employing the tap rule. Do you have one?
If yes, email it to me (whis11 @ charter.net) if your member status doesn't allow picture posting.
Thanks.
Larry Kage, CMI
231 929 3525
Old 8/14/10, 9:58 AM
James F. McKee's Avatar
I would really like to see that picture as well....
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 8/14/10, 1:11 PM
Unmoderated Guest
First it would help to understand that a tap has specific rules and conditions in which they can be used. A tap by definition has its OCP at the end, not where it originates. NEC Article 240.21 will spell these out.
No personal pics but here is one from another HI forum,
Old 8/14/10, 3:08 PM
There is no image, Jim, simply the red "X" box...
Larry Kage, CMI
231 929 3525
Old 8/14/10, 5:52 PM
Here's a 10' tap rule compliant installation. 400 amp feeder, #6 tap conductors (minimum 10% of feeder ampacity) to 15 amp circuit breaker. The lugs on the bottom accept two conductors (double lugs) in the #6 AWG to 500 kcmil range:
Old 8/14/10, 7:00 PM
Thanks.
Do the lugs at the top, that are hidden, have a similar design accepting two conductors?
Larry Kage, CMI
231 929 3525
Old 8/14/10, 7:03 PM
Originally Posted by lkage View Post
Thanks.
Yes, the load portion of the switch (top lugs) is factory wiring for a dimming system. The bottom portion is the feeder connection.
Old 8/15/10, 12:17 AM
Humberto Carvajal's Avatar
Humberto Carvajal Humberto Carvajal is online now
Nice pictures. Thanks for posting these.
Humberto Carvajal Jr.
Florida State Property Inspections, LLC
Florida Home Inspector License# HI884
LEED® Accredited Professional
Member USGBC South Florida Chapter
Double Tapping Main Lugs tdomingues Electrical Inspections 1 8/19/09 11:33 PM
Double tap at main lugs gmathias Electrical Inspections 4 8/8/07 7:20 PM
Main panel double tap dmccauley Electrical Inspections 20 1/25/07 5:31 PM
