Old 12/12/09, 8:08 PM
Bruce L. Treacy Bruce L. Treacy is offline
Cool Double taps
Can Square D breakers be double tapped. There is a small lug that appears to be able to handle 2 wires, one on each side of the lug.
Find an InterNACHI certified South Carolina Home Inspector (and anywhere else in North America)
Old 12/12/09, 8:15 PM
Michael Roberson's Avatar
Michael Roberson Michael Roberson is online now
Default Re: Double taps
Some of the newer Square D Homeline breakers can be double tapped.
This is how I tell the difference: Single screw, and compression = Single wire
Single screw with compression plate = Double tap (not sure the actual term)
http://www.nachi.org/forum/f19/squar...re-size-26314/
In this thread, the wires are installed poorly, but you can see in the photo the crimped plate below the screw.
Old 12/12/09, 9:02 PM
This is what to look for:
Larry Kage, CMI
231 929 3525
Old 12/12/09, 10:13 PM
Jim Port Jim Port is offline
Unmoderated Guest
The Square D QO and Homline are good for 2 conductors in the 15 and 20 amp sizes.
Old 12/18/09, 1:07 AM
George P. Wells, CMI's Avatar
Around here (Great Lakes/Upper Midwest), we call them saddle clamps. The terminology for electrical system components is not the same everywhere so they may known by other names elsewhere.
BestInspectors.Net
Windows - iOS - Mac - Android
Continuing Education
http://www.bestinspectors.net
est. 1992
Old 3/12/10, 9:17 PM
Gerald C. Wilcox's Avatar
Gerald C. Wilcox Gerald C. Wilcox is offline
Jim what documentation do you have on this......I have been reading online from the square d site and have not found this info yet.....
Thanks
Old 3/12/10, 9:31 PM
Jeffrey R. Pope's Avatar
Thanks
The listing is usually affixed directly to the breaker. When they are specifically listed for two conductors, it's no longer referred to as a "double-tap," unless both conductors are on the same side of the screw.
The term "double-tap" is generally reserved to describe an "improper connection."
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 3/12/10, 10:07 PM
Robert Meier's Avatar
In this photo, from Mark Shunk in that old thread, you can clearly see the wire sizes and connections for the square D breaker:
Old 3/13/10, 8:10 AM
and both wires have to be the same gauge. Had a electrician try to tell me the doorbell transformer(16 gauge strained) was ok on that 15 amp circuit with the #14 solid. Ask for his determination in writing, still don't have it.
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 3/13/10, 8:16 AM
Bruce do you think that's true when you look at the installation graphic on the side of the Square D breaker in the photo? I see #14-#10 as permitted to be both landed on the breaker. Maybe I'm missing something but I don't see any prohibition for different size conductors.
Old 3/17/10, 9:21 PM
pmassie's Avatar
pmassie pmassie is offline
Please Note: pmassie is a non-member guest and is in no way affiliated with InterNACHI or its members.
Square D single-pole. This breaker is rated for two conductors only, but many are rated for a single conductor only, so this is something to be aware of when inspecting the breaker. Square D and Cutler-Hammer currently manufacture breakers which are UL-listed for this application.
Old 3/17/10, 10:29 PM
Bill Smith's Avatar
Bill Smith Bill Smith is offline
The label on the Square D breaker states that it is listed for one or two wires.
http://www.SmithHomeInspection.com
SmithHomeInspection@yahoo.com
NY State Lic. # 16000008304
631-434-5200
Old 5/15/10, 7:42 AM
Steve W. Goddard Steve W. Goddard is offline
What about 2 neutral wires under one screw on the ground bar or a neutral and a ground wire together under one screw
Need a home inspection in South Carolina? Check out InterNACHI's listing of South Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/15/10, 10:06 AM
Unmoderated Guest
While commonly done in the past it was contrary to the UL listing. It has been spelled out now in the NEC so that the infomation is more readily available.
The rule is multiple grounding conductors are typically ok, but check the panel label. Neutrals must not share, nor be grouped with another conductor.
Old 5/16/10, 9:07 AM
Banned
If you had a #14 and a #10 installed, how could you ensure adequate pressure and mechanical tightening on the #14? That's why they ask for matched size conductors, so that equal pressure and holding power is on both sides of the saddle.
Double Taps in Cutler Hammer Panel bhartley Electrical Inspections 38 7/1/09 5:42 AM
Neutral/Ground double taps kmalone Electrical Inspections 6 4/24/08 5:26 PM
Double Taps rwand1 Canadian Inspectors 39 3/29/06 7:16 PM
Double Taps psmothers Electrical Inspections 3 3/9/06 10:04 PM
