Inspection today, these double taps go to a sub panel that operates the pump start relay for a sprinkler well, and also some of the stranded aluminum ground was left out to make room for the copper to the grounding rod, any thoughts on this?
Harris Home Inspections mitch@harrishomeinspections.com Your Central Kansas Pro-Sight affiliate www.prosightinspections.com/HHI |
| Find an InterNACHI certified Arizona Home Inspector (and anywhere else in North America) |
Just plain wrong.
I don't know of a kind way to describe such a mess.
When I see panels like that my first thought is, well that makes my job much easier. A licensed electrician needs to inspect and repair as needed.
David InterNACHI #08051301 NYS Lic. #16000038229 NYS DEC Cert # T4865884 518-505-8305 HouseAbout Home Inspections HouseAbout on Facebook NY Capital Region Chapter InterNACHI |
bump
copper and aluminum will eventually fuse together. |
You did the inspect part. |
I'm seeing more than double taps there, looks like at least three conductors under those lugs.
You could pick the application apart naming each defect or recommend evaluation and repairs by a qualified electrician. I'd recommend evaluation and repairs. Vince Santos
StepByStep Home Services LC (734) 748-9584 Providing Home Inspection Services to Southeast Michigan ITA Trained and Certified |
Typically see this when an A/C compressor or well pump or somesuch electrical addition is made by a non-electrician.
Call it out. Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
| Main panel double tap | dmccauley | Electrical Inspections | 20 | 1/25/07 6:31 PM |
| Double Taps | rwand1 | Canadian Inspectors | 30 | 3/29/06 8:16 PM |
| Double Taps | psmothers | Electrical Inspections | 3 | 3/9/06 11:04 PM |
