Old 4/9/09, 6:34 PM
Brian E. Kelly's Avatar
Default Double Trouble
Main and Sub
Find an InterNACHI certified New Mexico Home Inspector (and anywhere else in North America)
Old 4/9/09, 6:38 PM
James F. McKee's Avatar
Default Re: Double Trouble
was that one of Edison's earlier residences Brian ?
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 4/10/09, 11:30 PM
jkogel jkogel is offline
Dang I thought it was a triple-tap but it was just a double-tapped double pigtail.
Picky, picky.
Old 4/12/09, 9:40 PM
Picky, picky.
I wondered how to write it up myself John. I will use that the "next" time I come across it.
Old 4/13/09, 11:26 AM
Michael Roberson's Avatar
Michael Roberson Michael Roberson is online now
Inspector Lingo "The Main and Sub panels are out of date, and contain recalled parts. The wiring is unprofessionally installed, and will Likely cause problems in the future. Recommend a licensed electrician evaluate" Translation "This panel is crap, Im not sure what they were drinking that day, but whoever did this was a hack. replace it immediately if not sooner."
Old 4/13/09, 5:08 PM
Scott F. Coslett Scott F. Coslett is offline
Lots of 'classic' deficiencies in both the service and distribution panel depicted........all new inspectors should study these pics.
Thanks for sharing Brian.
Scott Coslett
National Property Inspections
Berwick, PA
www.PennInspector.com
scoslett@pa.metrocast.net
"Life is Tough. Its even tougher if you're stupid" John Wayne
Old 4/13/09, 5:58 PM
Jeffrey R. Jonas's Avatar
And to be truely educational, Brian could use arrows, text and such to identify each and every defect so the new inspectors actually understand what they are seeing. And to be fair about it, I very rarely see a FP/Stab Lok panel. How 'bout it Brian?
And yes, thanks for sharing!!!
Old 4/13/09, 10:41 PM
I do not see Stab-Lok panels that often either. So when I do, I write, you have Stab-Lok panels and need an electrician.
No Arrows and Text.
Old 4/14/09, 9:50 PM
Andrew Cox Andrew Cox is offline
I wrote up a StabLok panel on a condo 2 weeks ago. The seller found an electrician whose opinion was that it had been working for 30 years without a problem.
He actually wrote that the panel was acceptable and he saw no problems!
Andy Cox
http://www.CoxInspections.com
Kissimmee, FL
You’re Your Own Job Security.
Old 4/15/09, 12:18 AM
Mark E. Northrup's Avatar
Mark E. Northrup Mark E. Northrup is offline
I see alot of Federal Pacific Panels with stab lock breakers. They are pretty common here and alot of the electricians will state that they are ok. Just make sure your verbage states that:There are many known problems with the panels and the breakers and to have a electrician further evaluate. If the electrician calls it good it is on them. Not You.
There are so many writeups in both of these panels that a electrician should further evaluate the whole system. There is lots of info on line about them as well as Zinsco Panels.
Old 4/18/09, 12:40 AM
Old 4/18/09, 7:29 AM
Originally Posted by bkelly2 View Post
Well, at least they have the stove breaker marked.
Larry Kage, CMI
231 929 3525
Old 4/23/09, 3:02 PM
Randy D. Stufflebeem's Avatar
Randy D. Stufflebeem Randy D. Stufflebeem is offline
How I write FP's up and leave it up to them:
Federal Pacific Stab-Lok® Electrical panels may be unsafe. See www.google.com (Federal Pacific)
Old 4/23/09, 3:34 PM
Bob Elliott's Avatar
Which parts are recalled?
Old 4/24/09, 4:22 AM
Double lugged breakers? dbook Electrical Inspections 7 4/30/08 12:35 AM
Double Mast,Double Trouble? belliott Electrical Inspections 4 7/5/07 11:35 PM
Double Tap Questions jkogel Electrical Inspections 6 6/28/07 9:46 PM
Toronto Convention now just $99! gromicko Canadian Inspectors 36 4/3/07 12:22 PM
Double Taps rwand1 Canadian Inspectors 39 3/29/06 7:16 PM
