During our CE this year the instructor told us the if the contact under the screw has a slot on both sides of the screw then the breaker is not double tapped. You agree.
Thanks. HOM does that stand for homeline or something else? Thanks again Michael.
you did comment on the over spray right
Bungalows to Mansions Professional Inspection Services, LLC dba 1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
How about one of the "Sparkies" give us an opinion on this? |
hmmm..what comment ya want...
I can't see the bussbar and contact points from the breakers to the buss to I wont comment....does not look excessive to me. Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
How about your professional opinion. Does that mean you wouldn't comment on this in a report? My opinion is that while contamination is not permitted within the panel, it is because of the potential to reduce required spacings between parts of differing potential and affect the characteristics of insulation of conductors and components within the enclosure. So for the pic in question it becomes a judgment call. Other parts of this panel may or may not show additional contamination and may or may not indicate the need for repair by a qualified electrician. If in doubt call it out. |
The overspray is not a big deal in this particular panel. I wouldn't write it up.
As for the double tap at the breaker....If it contains a double style retainer like this... "Click To Enlarge" ![]() it's allowed per the manufacturer. |
Marc Benz is a non-member guest and is in no way affiliated with InterNACHI or its members.
The SqD QO® and the HOM® both are rated for two conductors [ wires ] on the breaker termation clip [ note this is covered both single and double pole breakers from 15 amp to 30 amp size ] larger size breakers [35 amp and up ] are rated for single wire only
the same thing with the CH [ Clutter-Hammer] the CH series and BR is the same thing too they are listed for two wires unless speficed somewhere else I dont know about other breaker are listed in the same manner what the SqD and CH have in thier products but i really doubt it. Merci, Marc |
and they wonder why the home owner or buyer gets confused Will Decker, CMI ILL License # 450.0002240 Board Certified Master Inspector Decker Home Services, LLC Chicago and Northern Suburban Home Inspections Office: (847) 676-8393 Cell: (847) 609-2345 Home: (847) 673-2702 wjd@DeckerHomeServices.com www.DeckerHomeServices.com Learn, Educate, Serve and have fun doing it! |
Paul:
What's the ruling when you have a legal double tapped 15 amp single breaker regarding total number of outlets protected? In Canada, we are allowed 12 outlets per circuit and I assume that (will find out later today) a double tapped 15 amp breaker will be allowed to protect 12 outlets only. |
You do have a valid point though. Why legally manufacture a breaker that can accept more than one circuit which can cause an overload if not properly calculated. I would assume that the Electrician who connects two circuits to these specific breakers is doing a simple load calculation. Ya right....I highly doubt it. |
| www.InspectorMALL.com doubled in size this year. | gromicko | Miscellaneous Discussion for Inspectors | 0 | 10/4/06 11:07 AM |
